Pupuhd
Been reading alot here about compressors and today I picked up a Westinghouse Air Brake Co. Type Y air compressor, Model 2YC, Seriel #127047. I currently have a Craftsman 26 gal. compressor which I last year replaced the tank. However I'm using it more and more in my basement shop and when I do any grinding, sand blasting it barely keeps up. I've gone through several compressors in the last decade or so and it was time to move on up to the big boys. I didn't want to purchase a new or like new due to NO BIG MONEY, I wanted to build/rebuild a 60 or 80 gallon 2 stage compressor. Something I know will last for nearly ever and will keep up with my currnt projects and any future needs.
While searching through CL, I was looking for an Ingersol Rand T30 one but came across this ad last night. The seller had not real information except for it was approx. 30 years old that was included with a mechanics garage that he purchased. He stated the garage was built in the 60's. The pics he had looked like a T30, I was unable to determine. Luckily for me it was right up the street about 10 minutes north. I went to look at it and realized it wasn't a T30 but a Westinghouse 2YC. He was asking $150 obo so I told him I needed to check if parts were still available. Within an hour went back and offered him $100, he forklifted onto my truck and the rest I hope is a happy beginning.
I have many questions for you guys so to start he are some pics to wet ur apetite.
It has a General Electric TriClad Capacitor Motor: 3 HP, Phase 1, 1750 RPM, Volts: 115/230, Amp: 29/14.5.
Maybe some of you may notice something or many things about the tank. it measures 24"x46", which I assume is a 80 gallon tank. However this is not the original tank that came with the compressor. Sometime in it's life some one swap the original for this one. There is no ASME label, tags, stickers, etc of any kind on this tank. Only stampings of some id numbers on the rear of the tank above the horizontal weld and two identical stampings on each end. Strange thing is that on the stampings on each end there are a set of X-X stamped perpendicular to the numbers. These X-X markings are also found throughout the pump parts, except raised. Does anyone know what this mean?
Second this air tank, I don't think it was meant to be an air tank. One or two of the three ports were Jerry-rigged. Someone welded a round thick bead and then drilled/tap holes. Not the usual donut ring shape you normally see around a port. E/w I was looking for a pump and motor and was going to later on purchase a like new vertical 80 gallon tank for the build.. I can either scrap the tank and get maybe $20-25 or repurpose it for a Sand Blast Cabinet. Not to mention two other important setbacks: there is no port at the bottom to discharge water and someone after moving to the back of the garage drilled a 3/8" hole on the bottom right to maybe remove all the water in it.
Here are the questions that I hope you guys can answer, give advice, opinions, suggestions, blah, blah, blah...........
1- Can this tank be re-certified and fixed as far as fixing the jerry-rigged holes and creating a new one at the bottom? Would it be more economical to just find a vertical 80 gal one and use this one for a Blasting Cabinet? After much reading and consideration for safety, I've decided not to try any attemp to use this tank for the compressor, cost prohibited and safety. I will clean & store it to see if I can repurpose it as a sand balsting cabinet in the near future.
2- Does anyone know where I can find, download, buy a manual for the Westinghouse pump and/or the GE motor? Also, any specs, websites, details, photos, color I can go to in order to get more information?
3- Any information as to what to purchase and how to wire this motor with a starter?
4- Any other things regarding the pump and motor I should check for or consider during the rebuild?
5- Was this a good buy for $100 considering the tank may not be able to be used except for scrap metal or a blast cabinet? Head Overhaul kit to Rebuild One Westinghouse Air Compressor Model 2YC is $65-$70 (just for thought).
6- Can anyone determin the pump information as far as pressre, CFMs, HP? There are several Patent numbers on the side of the pump if this helps.
This is going to be a slow rebuild, as time and money permit, so I'll have tons more pics and questions as it goes along. I'm hoping with some ideas here I can slowy purchase certain items at a resonable prices. There is a steel/surplus place 30 minutes north of me. They have surplus electrical stuff, equipment, etc. Maybe I can pick up some of the smaller stuff like a NEMA box, starter, Air guage.
For now I have my work cut out for me. It's still stitting in the back of my truck and will have to dismantle piece by piece in order to power wash and get downstairs. The tank I may just clean and put in one of the sheds out back until I decide what its future is.
