I need a little help. In my garage I have a small sub-panel that has a 50A breaker, and a 30A breaker...The sub-panel is fed from my main garage that's 60' away. There is a 4 prong receptacle for a welder which I don't use. So, I wanted to take the receptacle out, and wire directly into the receptacle where the welder plug was...Now, can I leave the 50A breaker there for the 5HP 230 V compressor. The amp draw as far as the specs on what I have read draws 28 amps...I was going to leave the 50A breaker and go with 10 THHN wire. Where the 4 wire in the receptacle is, just cap off the white neutral...I want to leave the existing 30A breaker there for my small compressor. Just switch that breaker off when using the 50A. Is the 50A breaker to big?, or do I change that to a 40A to feed the new compressor? Or, do leave the 50A breaker and run # 8 wire? I did a search, but there is so many contradicting opinions...
