Need cutting torch info and recommendations
jeopardy98
Prince George, VA
So I was out today buying some tools at a garage sale and this guy asks me if I want this acetylene torch and bottle. I've been wanting a cutting torch for a bit because I do a lot of work on old 3 wheelers and such and sometimes you need to cut through a frame or a swingarm or axle and obviously MAPP gas doesn't really do the trick.
I know nothing about cutting torches though so any advice is appreciated. I don't even know where to start. I've been looking at the port a torch at Home Depot and I've seen lots of torches/tips on Craigslist but I don't even know what I need for my purposes.
I think I probably paid more than I should have for what I got but after looking online briefly I didn't feel like I could walk away and not buy it so I did. It seems to be a very old model and I'm sure the hydro on the tank is WAY out of date. It appears to be a 10CU tank. It only has the one tip.
Would I be better off to sell this and save up for something else? Should I keep this bottle and add an oxygen bottle from somewhere?
I'm so ignorant on all of this and trying to find a cutting/welding torch 101 online isn't producing much beginner stuff.
Below is what I bought for $80 so if I should try and sell it and buy something else what should I be looking for and what kind of money is a good price? Is this tank worth keeping and trading in or should I just sell it and buy a complete kit?
Thanks in advance for any help.
dr_clyde
Holland, MI
That is an air-acetylene brazing and soldering torch. You can't cut with it, because you need an oxygen jet to do the cutting.
zkling
Yea, that's an HVAC or plumbers type of torch, with a B tank. Brazing and soldering is going to be it for that.
The Cobbler
you have a B tank & plumbers torch.
you could use the btank for acetylene if you don't use it much. here, you own the tank & just exchange when need a fill. you can buy adapter to mount an acetylene regulator for a oxy acetylene set up. I bought a ****** & replaced the ****** on the acetylene regulator .
I have 2 b tanks , one is always full . the occasional times I need oxy acetylene, I have a set that I conect to my b tank & small owned oxy tank. no rentals or contracts but not very efficient if using it a lot ( especially cutting with the small oxy bottle)
J
jeopardy98
Prince George, VA
Okay so this isn't really what I need or want but it seems I did okay on the price. If I were to sell this for what I paid or a little more what would be a good setup to buy? Is the B tank worth keeping to use with an oxy/acetylene setup? Or should I just sell it as is and buy a larger bottle setup with a torch on Craigslist. Would the Port a Torch setup at Home depot serve me for my occasional purposes?
dodge610
North Canton Ohio
I would get the next size up from the b tank if you cut much at all you will drain that tank pretty quick. The next size up from that is a s tank If I remember right. The matching oxy tank should be a Q tank if there still calling them that.
dodge610
North Canton Ohio
Torches you need a combo torch that will cut or braze. You could check craigslist for a rebuilt airco torch and gauges or just go with a victor set. I think the victor set is a journeyman set.
metaldad
nw indiana
oxygen cylinders:
acetylene cylinders:
lilredex
Toronto
This is my set up, it uses the same "B" tank you have, (40 CF) with an 80 CF oxygen tank, with a Victor medium duty torch set up.
It will allow a bit of cutting but will not support that rosebud tip, I use the cutting head for my heating needs. Have had it for more than thirty years and it suits my welding/brazing/heating needs.
brownbagg
keep it, that a great setup for brazing and plumbing work. its worth more just sitting in the shop than you can get for it. if you must, get a small oxygen tank and use it for gas welding. it never be big enough for cutting. but once you master gas welding then tig is simple
