How do you waterproof the garage door opening?
enochian
So I can use a hose to clean garage floor....
soapii
SE Michigan
You have to better explain your question. What you are describing sounds like you are trying to keep water IN the garage.
--Joe
maxpower_hd
Massachusetts
My floor is pitched slightly toward the door. I hose down the floor then use a squeegee to push most of the water out then run a fan to dry it.
On the opposite, with the door closed there is a rubber gasket at the bottom of the door and a slope that keeps the water out.
MikeF
Same thing I was thinking. I don't understand his question.
OP, by nature of being an exterior door, your garage door is already waterproof.
--Joe
Water resistant is a better term. Water will still get in if the apron settles and pitches back. Or is your door is on the side of your garage that gets hits with rain. The corners where the bottom seal meets the stop seal is usually where water enters, or the stress cut/groove on bigger openings
black4.6gt
Eastern WA
I wouldn't be worried about getting the framing around the garage door wet, as long as the wood doesn't always sit in a puddle of water.
I find myself spraying out the last few feet of the garage with the hose often, but I am not focusing the jet of water on the wood.
coldh2o
Ontario, Canada
^^This.
Put some vinyl molding on the wood framing if it bothers you. Roppe is a popular brand.
^^ Not this. Unless you get a really good seal, I would be worried the vinyl would trap water between it and the wood and not let it dry.
You could caulk any gaps and paint the wood.
CNGsaves
KS and OK
^ ^ ^ 2nd part. OP being worried about door opening, then he should just PAINT any bare wood with multiple coats of primer after he's caulked any gaps in the wood. Then finally couple coats of final paint color.
buddyboy
a good coat of roofing tar or driveway asphalt sealer should keep the water out of the wood.
to be extra safe you could staple some plastic grocery bags to the trim and then paint the roofing tar over that (thin with gasoline)
use a propane torch to dry the area when done
ok... i'm joking
