Where can I find the cheapest decent triple square bits?
winlinmac
USA
I see Autozone having them for $31.99
I can't find them on Harbor Freight's website.
Any suggestions? Applicable to European Vehicles.
Thanks
Mikerodrig27
It's hard to pass on the VIM unit above. I don't do much work on Euro vehicles but how often do you need a triple square on them? The only time I've ever needed it is when I had to remove a shroud for an oil change on a beetle.
shockwave
Marietta,ga
Mostly use these for is rear caliper brackets on vw Touareg and rear toe adjustment on Mercedes Benz it depends on what work you do on German cars oil changes most likely not but general maintenance shop I would invest in 1/4 and 3/8 atleast
rick carpenter
Huntsville, East Texas
I used an 8mm hex-body triple-square bit on an 01 Jetta door a while back. I bought a no name four piece 2-7/8" USA set at a local parts house and had to have the 8mm bit cut down to 1-7/5" to fit. I think there were only four tri-sq's on the whole car! I don't remember the price but it was good.
Skin
Boston
Cheapest and bit sockets generally don't go well together. May as well throw your money in the trash and save yourself a trip to HF if you'd actually consider that place for this particular product. And this isn't just a random HF bash, their hex and torx are often improperly sized which leads to a much bigger headache when it either breaks off or doesn't fit stopping you in your tracks.
VIM are a known quantity (good quality) and about as cheap as you'd want to go.
Mikerodrig27
The VIM set is already so cheap and VIM products are so well spoken of. I think that if you are going to use a triple square on fasteners that are in good shape and you don't plan on using it that often then a junk set will cut it.
WhiffySpark
Until it strips out and you're freaking screwed.
I have Cornwell I believe their vim. Both my Mac and Cornwell sets look like vim
Mikerodrig27
Hmm, I've used cheap triple square sets and have had no issues. I even used them with an impact driver.
Bro-Hio
I just recently bought the Capri Tools triple square bit set from Amazon for the same thing, VW work. They are good quality and come in a nice case. They held up and still look new after me beating on them pretty hard with a breaker bar trying to get my rear calipers off. I think they are around the same price, $20-25 bucks shipped if you are a Prime Member. Just another option to think about.
purplezr2
Central MN
I have a blue point set(VIM?) that have treated me well. I have a long snap on one that I use for VW/Audi Axles(12 I believe) and I have a long 10 for doing older head bolts.
W
winlinmac
USA
From Wikipedia, :)
The triple square, also known as XZN, is a type of screw drive with 12 equally spaced tips, each with a 90 degree angle. Common sizes are 6, 8, 10, and 12 mm. Its name derives from overlaying three equal squares to form such a pattern with 12 right-angled tips (a 12-pointed star). In other words, 3 Robertson squares superimposed at 30° rotation. The concept is similar to that of the double-square—in both cases, the idea being that it's like a square (Robertson) but can be caught at more frequent angles by the driver bit. These screws can be removed with standard Robertson bits.
Triple square drives are often used in high-torque applications, such as cylinder head bolts and drive train components. The heads are hardened and tempered to withstand the driving torque without destroying the star points.
Triple square fasteners are commonly found on German vehicles such as Audi, BMW, Opel, Mercedes, Porsche, and Volkswagen.[48]
Never heard of tripple square, is this the same as torx?
W
winlinmac
USA
Reading a little more into the reviews on Amazon for the Capri Tools set, some say the bits are too short, but the item description does not indicate whether or not these bits are stubby-type. The VIM Tools discretely state stubby. Not sure if this really makes a difference or not as one can always use an extension to aid.
Zrexxer
Pflugerville, TX
I prefer short driver bits, they're less likely to twist on you. They only need to be long enough to fully engage the head of the fastener.
W
winlinmac
USA
Even the VIM Tools are Made in Taiwan, but expect better quality as they are the OE for some of the major truck brands
1949 caddyman
Arizona
I didn't work on German cars, thats why I never heard of the triple square. You learn something new every day!
Adam.C
+1. Cheap triple squares are a REALLY bad idea. These are used in high torque low access applications. Brake parts, half shafts, engine mounts, seat mounts. You often won't get a second chance with one of these.
W
winlinmac
USA
Haha, no wonder they offer lifetime warranty for that second chance. :bounce:
Itinker
Atlanta
W
winlinmac
USA
Thanks, I can't seem to find them on Amazon. I guess I'll have to resort to Capri Tools for this one. They all are Made in Taiwan.
The 9pc VIM Set XZNS1000, includes bits in 1/4", 3/8" and 1/2" drives.
K-Dog
Millersville Maryland
Let me jump in. I also have the VIM set. Way stronger than they look. I am very pleased with these sockets. A few of them are quite high milage and still fit great.
W
winlinmac
USA
Thanks :) VIM Set it is then. Can't wait to order before I begin suspension work
