OSB and Studs
schmiddlicous
I am going with an OSB wall but the studs are not spaced right. Is OSB strong enough not to worry a about meeting osb at the Studs?
buddyboy
i would think all joints would end on a stud, osb, drywall, plywood, wall paper, plate steel...
tac
Colleyville Texas
Interior wall or sheathing? You may get away with the h-clips used for roof decking but I would personally tie it to a stud or block if used for a wall. You can rip it to fit or add extra stud or nailer block to fasten it to.
laser3kw
northen IL
if the wall length is not a perfect multiple of 48, your short (narrow) sheets go in the corner(s). You then hang full width sheets across the remaining studs, they will meet at the studs. If you still end up without a nailer in the corner, sister up (double up) a 2 x 4 so you can nail into a solid stud. Also bump them up tight (1/8 gap ) to the ceiling (factory edge) and leave your gap (cut to length end if needed) at the bottom to be covered by your 1/2 x 4 kick/ trim strip.
gdh33
Northern Ontario, Canada
If it is for exterior application ensure that the sheets are as large as possible, staggered seams and that the ends line up on a stud. If need be rip the sheets before install or set the depth of your circular saw and use a 4' level to mark stud location on installed sheet and rip it in place.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
I second for ending it on a stud, or maybe third it :dunno: but you want your ends, or sides if hanging vertically to land on a stud. 2x's are cheap, so you can add a stud in where you need one. Toenail top and bottom, and if possible, nail the sheathing on the outside to that stud. If that is not possible, at least add a stud in for the ends or the sides and toenail the stud in.
Shiftless
East Bay SFO
Maybe some pictures would help us give advice. Wall studs are almost always 16 inches apart measured from the middle of one stud to the middle of the next one. Carpenters call it sixteen inches on center. 3x16 = 48 and 6x16 =96 so your sheets of OSB should fit fine. Lay up your full sized sheets first and then trim sheets down to fit into any odd corner spaces. All edges should be nailed to solid framing or blocking that you might have to add. No big deal.
finn
The UP, God's country
Add a few studs. They are less than $2.50 each last time I checked.
Make sure you put a mark on the floor or ceiling so you know where to set your nail pattern for the misplaced studs.
schmiddlicous
2 walls that need to be done 28 x 9 and 30 x 9... I was going to go vertical with 12ft Osb. Maybe it might be better to go long ways instead..
tac
Colleyville Texas
Are you talking about the seam top and bottom? If so most codes require fire blocks between the studs for walls over 8 ft. Add these at the right place and it gives you something to nail to.
k-os
WI
The panel will be stronger if you install it horizontally.
Falcon67
Merkel, TX
Land on studs. If you have to, add studs to the wall or double up existing ones. Had to do that for my Hardi, it adds very little cost to the whole thing.
FunkyfullWidth
Three Rivers, ma
The guy that owned my place before used crating osb plywood. It measured a little over 7 feet and a touch under 4 feet wide. Needless to say, 90 percent of the wood did not meet the studs. Some of them I fixed by cutting them down but it creates a lot of waste and makes it kinda goofy. I can't afford to replace it all, or really cut it all down and go out and buy new stuff, so in the few places where I pulled the wall down and put it back up (for whatever reasoning I had ha ha) i would rip a 2x10 and stuff it up in the wall to have something to add some rigidity to the seams.
For a new build, or open wall.. if it's not too crazy, i'd consider putting a few studs in place 16 or 2' oc instead of making a boat load of cuts on the osb.
CNGsaves
KS and OK
OP . . . . what country are you in ?? Update GJ Profile with location.
Possible that "anything goes" might be standard protocol for Siberia Russia ?? :D
