I have a 4 bay garage, three abreast and the left bay two deep. I use the deep bay as a workshop. It's all automotive use, storing the daily drivers and a weekend "toy". I do automotive work in the garage, but nothing heavy. Little to no welding, just wrenching, etc.
Here's the problem. The garage is full of stuff, including a very heavy, hard to move 4 post lift. I don't know many people around here, so this is absolutely a me only job. Moving the lift by myself is a near impossibility. Also, if I have to empty the garage out completely, I really have nowhere to put the content for days at a time.
Given the above, while my first choice would be a beautiful epoxy floor with heavy flakes, the tremendous amount of prep, with grinding, patching, etc, will takes days and days and days, all the time with my "stuff" outside, and me making an absolute mess in the garage, working my tail off. Also, wondering what I would do with the lift in the meanwhile. None of this sounds terribly appealing to me.
Of course I have the option to pay someone to do it, but that's hugely expensive and doesn't solve the problem of what to do with the lift, and what do do with the stuff that's in there already while the folks I hire do days and days of grinding and prep.
I'm thinking that I need to do something that:
1- I can do a section at a time, moving my stuff from one bay to another, do the floor in that empty section, then move my stuff back to the section I just did and continue, etc. That would also seem to rule out epoxy, as I believe that you'd see where I started and stopped.
2- The darned lift again. I can't move it by myself, so I will have to work around it.
Given all that, I know what I do NOT want - any sort of ceramic or porcelain tile. I just don't want that in the garage. That seems to leave me with the following choices - very thick, heavy commercial vinyl tile, the plastic type interlocking floor tiles, or some of these new floor "paints" that some of the flooring experts on here seem to be talking about.
I'm not real big on the interlocking plastic tiles because they're very expensive and the few that I have seen are really noisy. I know this sounds crazy but to me they "sound" cheap. The constant clicking and clattering would drive me nuts. They also seem to be about the highest per sq. ft. charge. I don't even know if it's possible, but if so I'd like to keep the cost of this floor at about $2 per sq. ft. or less.
That seems to leave me with choosing between the commercial floor tile and learning more about these new paint type products. I know they're not just paint, but I don't know how else to describe them. I tried doing a GJ forum search on both the commercial vinyl tile and these new paint type products, but the amount of non related stuff that pops up on search is just overwhelming.
If I did the vinyl tile, I imagine that I will need to buy considerable extra to replace damaged and stained tiles over the years. I get that, and I have no problem doing that.
If I use one of these paint type products, can I do one section at a time? The floor is in reasonable condition. There are a few chipped areas, seams etc that I would like to repair. What other type of prep does these new products require? Can they be flaked? If the stuff is durable, resistant to tire lifting, and can be flaked, I would be very interested in learning more. If it can't be flaked, but can be done a section at a time, I'd still be interested in learning more.
I know vinyl tile has it's drawbacks, it will be damaged, etc. However, the cost and ease of installation is appealing to me, and it's so easy and cheap to repair tiles that get damaged. If I went this way I would buy a ton of extras rto have on hand for repairs over the years.
The newer paint type products have to be as durable, or almost as durable as epoxy for me to use them, as I imagine the floor after using this product can't be easily repaired seamlessly if ares of problems pop up.
Lastly, of course, if I am wrong in my assumptions about the interlocking plastic tiles or my understanding of the pitfalls of applying epoxy (clearly my first choice), please let me know.
Lots of questions here, I know. Any info and light you guys can shed on the subject would be appreciated. I'm now in the process of running the air lines (copper), electric, etc. Then I'll insulate and sheetrock the walls. I anticipate that if all goes well I will be doing the floor in the December to January timeframe, as I am doing all the above work myself when I am home and not working.
All thoughts, ideas and input are welcome.
Thanks!
Thanks!
