O-ring pliers
babylou
I'm looking for a rapid method to install a #016 o-ring repeatedly onto a piston groove. I know of a machine I can buy but I have to wait 6 months. Anyone seen a 6 point version of something like this:
matt stott
Boston, USA
We use tools that look like funnels. Put the wide end of the "funnel" over the piston and slide the o-ring over the pointy end. Just need to roll the o-ring up to the wide end of the funnel and when it goes off the wide end it pops right into the piston groove. It might be easier to find a cone-shaped something that you could custom-size to fit your piston perfectly- often quicker and easier than trying to load those pliers up with rings, and simple enough to make a custom sized tool.
Wish I had a photo of one, much easier to understand with visuals.
Pen caps and golf tees work for much smaller o-ring installs, too.
Matt
babylou
Matt
In this application rolling of the o-ring is forbidden.
zakmartin
Seattle, WA
Maybe there's a set of medical retractors you could bend the prongs on to custom-suit your needs.
babylou
Check the vet store for the tool that they use to put the bands on sheep. Kind of like the pic you posted.
The pic is a sheep banding tool. I've ordered one to fiddle with. I'm looking at 2400 orings a month. The machines are about $10k each. I've already spent at least $400k on this project. It's starting to rub me wrong.
ChevyEFI
Phoenix, AZ
Hmm. I'm picturing a thin, slitted cylinder, driving the o-ring off a smaller o.d. cylinder.
Or a thicker solid cylinder driving the o-ring off a smaller o.d. thin, slotted cylinder.
There are possible approaches to avoid rolling.
babylou
Already designed this but alas it requires two operations so is not optimal. It's still in the running but hopefully not for long.
