I have a wood stove that my grandfather built in the 60's that has been passed down to me. my first initial thought was to use it to heat my garage, however I feel it will be better suited to help heat my home since my heating oil in my area is pretty outrageous, and I think the stove is a bit large for my 24 x 24 garage when it use to heat a much larger log cabin in upstate New York. my home is 1200 sq ft, single story with a basement and an existing HVAC system.
my question is, how could I use this wood stove to share the ducting with my central air furnace? I have 2 returns on the main floor, but none in the basement. could I just simply add a return near the wood stove in the basement so the radiant heat goes through the ducting?
also, I have a chimney in the middle of my house that a pipe from the furnace goes into, (see attached photo) and there is no fireplace in the house. can I do the same with getting the smoke out of the wood stove, or would the smoke make its way to the pipe coming out of the furnace? ideally I would rather go through the chimney than through my foundation wall...I'd really like to know what the purpose of this pipe from the furnace is
