Any of these compressors discussed will be fine for occasional use (no more than a few start/run cycles per hour). If you plan on serious continuous air usage, then their life will be shortened accordingly. I have been using a consumer-grade IR 60-gallon single-stage compressor for the past 25 years that I bought new. It is fine for 90% of what I do. But if I use air for more than 5 minutes continuously, it can't keep up, and I'll get a lot of water vapor blowing out the end of the line as well (yes, I need to install a water separator at the end of the line - the one right at the compressor doesn't do much).
So I have collected a few 'serious' compressors now, including my bucket-list compressor, a Quincy 325, that is awaiting a 3-phase to single-phase conversion so I can power it at my home. This Quincy will run continuously and not break a sweat. But it weighs more than 500 lbs. more than my IR compressor does!
Agree with the above, do the maintenance - scrap the drain petcock and go with an auto-drain, or at least a ball valve so it's easy to drain. It's no fun crawling around on the floor with the slip-joint pliers fighting the spiders trying to drain the tank.
