Building too seriously
Shocker
Olympia, WA
I have read most of the posts that you (Tcianci) has posted and I think they are well written and trying to be helpful. I guess that is why I don't understand the attack on the amateurs (well at least I feel that way) for putting more into our projects than you would.
As for "with Tyvek you probably won't even see the 20 year mark" comment. That is not true. Having some free time today, I made some calls to local builders, building inspectors and insurance folks. I talked to about 15 people in my home town and some folks in Seattle. Not one person has EVER seen a building destroyed or failure attributed to Tyvek. One guy has been wrapping homes in Tyvek for 35 years and all his homes are still standing with the exception of 2 (burned down).
Tyvek hit the market in 1967 and hundreds of thousands of homes have been wrapped in it. I cannot find any information on Tyvek failures. There is info on Tyvek failures when it is improperly installed or used with incompatible materials (cedar and stucco). But alot of those issues were from the 70's and early 80's and the makeup of Tyvek is different now (but still not for use under stucco).
Anyway, show us some examples of all the ruined structures that were wrapped in Tyvek and provide the corresponding documentation. Thanks
sammerdog
West Michigan
...There is info on Tyvek failures when it is improperly installed or used with incompatible materials (cedar and stucco). But...
Howdy Shocker - not to hi-jack this thread, but you indicate that Tyvek shouldn't be used under cedar..... uhh-ohhh. The front of our home is done in a cedar plank. And I expressly remember seeing the word "Tyvek" on the underlying vapor barrier during construction back in '93.
....in a nut-shell, what (if anything) should I be on the lookout for?
BooUrns!
Edmonton, Alberta, Canada
That would depend on the way your cedar was installed and the climatic conditions in your area. Cedar retains moisture more than other woods and should be firred out from the wall to allow air movement on the back face of the siding.
sasquatchpa
It shows that there are two sides to every story,
when I hear unsupported rants,
I think of Fox news or Rush L.
FunfDreisig
Gosh I hope not too many GJ members will be seriously offend if I keep on "Building too seriously" in my typically ****, obsessive-compulsive attempt to build the very best 3 bay garage i can, limited only by my novice design/construction skills and budget for materials.
After all, this will be the last (and first) garage I will build before being wheeled off to the old folks home. I want to have some seriously boring design/construction stories/pictures to pull out any time those other old coots start yammering on about their retirement achievements (e.g. golfing, watching football, sleeping in a hammock, etc. ). I can't wait to tell them (for the hundredth time) how cool it was to stain & poly-urethane the twinned 4' OC 2x8 Doug fir exterior rafters before they were installed and ... oops ... maybe some of you will be in the same retirement home, so I'll wait to bore you to tears then :)
Funf Dreisig
nate379
Palmer, AK
I hope I never make it to an old folks home. If I need help to live I need to be brought out to the field and be put down just like an old dog.
FunfDreisig
Hopefully I'll keel over while working in my garage during yet another ****, obsessive-compulsive project -- like the restoration of my late 60's 911, late 70's 530i, etc.. The seriously boring garage design/construction stories are just a contingency plan in case a gun isn't handy when they come to get me. As a good friend is fond of saying, "just shoot me" :)
Funf Dreisig
Ironcrow
Arizona
You would think that a guy in the industry for 40 years might have noticed that "the construction techniques of super insulating, sealing and caulking, wrapping and all of this other new-age hocus pocus" is actually becoming the code (ie minimally acceptable).
I'm building my own house and doing almost all of the work myself. I've had licensed contractors do a couple of parts of the job. Everything I paid somebody else to do, I've had to redo myself or complain until they redid it (barely acceptably).
My building is tight, insulated, green, and absolutely will NOT be falling down.
ket-tek
Sometimes it doesn't make sense why someone is researching and talking about something like insulation to the nth degree, but I bet they're in the process of insulating a new structure and simply want to gather as much data as possible so they can make an informed decision (whether they hire a contractor to do it or they do it themselves).
I feel that the above senerio hits the nail right on the head for most of the members postings that go into extreme detail.
-Information is power.
Whether the reason is to save money, pick a contractor, or to choose the best option/product.
At least people are learning, although that scares 40yr contractors when people learn that 'code' is ok, but doens't mean it is energy effecient, cost effective, or the best/right way to achieve great build.
kwb
PNW
I tend to agree that our codes are getting silly with the tightness required. We now have to build so tight that we then intentionally cut a hole and **** in outside air to maintain healthy environment inside.
I just did a remodel and my contractors steered me towards tar paper instead of tyvek, they said that it was not uncommon for them to tear into a 20yr old house that had been tyvek'd and had mold/rot issues. They said that they tear into much older houses with tar paper and rarely find similar problems. My house is ~20yrs old and was done with tar paper and there was no problems where we tied new to old.
You never used to hear of mold problems .... now its not uncommon I attribute this to air/moisture not being able to move in/out of building as freely as they used to be able to.
nate379
Palmer, AK
Sure... but do you like heating a building that is like a screen house? I don't.
My house in Idaho was built around 1910 and you can darn near feel a breeze blowing in the house when it was windy out.
-B-
Northshore of Boston
Garages and house of yesteryear can not be compared as the house were built to last several life time and a garage was meant to be cheap and temporary. 30 -50 year life spans are the norm for garages built up to and including the 1970's 2x3 wall studs and 2x4 rafter with 35 year roofs that were never meant to last longer then a replacement.
When I get the chance to build it will be part old ( pine sheathing) part new insulation framing will also be a throw back hybrid of timber, balloon and stick. Wall will be quit thick and strong to support weigh and take the ages. The slab will be a very large geo mass to stabilize the temperatures. ( if the site is right there will be a basement and sub basement) Siding and roofing will be of the new age materials with copper gutters and down spouts to a french drain that will feed the garden.
Shocker
Olympia, WA
I don't think so. The statements on cedar had to do with buildings done in the 70's and early 80's. The formula of Tyvek back then seemed to react to with cedar.
I do agree that we are getting pretty crazy on the tightness of homes built today. I haven't read much on mold infiltration with Tyvek, but I suppose it could happen. I just don't think that if you have a house wrapped with Tyvek that it is going to hell in a hand basket in less than 20 years.
nadogail
Coronado, CA
I have been sometimes been amused at the posts about how to build or even decorate garages. I came to the conclusion that garages are different things to different people. For some of us they are places to keep our things and work secure and out of the rain and cold, it is all relative; even the weather. I am happy to have "good enough", while others are looking for something closer to perfection. Well, I guess it is like beauty, All in the Eye of the Beholder.
Altho I may disagree with what some have posted, I will defend their right to post their opinion.
nate379
Palmer, AK
My house is built tight enough that without a window open it's almost hard to close the door main. If you swing it closed it won't latch. You have to pull the handle closed.
Open a window and I have to be careful not to slam the door.
I'm not sure if this is the case elsewhere, but in Alaska we have a energy program. Houses are rated on a system that goes from 1-5 star plus. 5* plus being most efficient. They have a $7500 rebate if you buy a 5* plus.
Mine is only 5* though. Mainly because I don't have a whole house recirculator. I don't remember exactly how it works but it mixes outside air with inside, heats it and puts it in the house.
I just have a powered vent that pulls air from the house and puts it outside. The supply air comes from a vent in an inside wall that runs up to the attic. Pretty much have to create a leak because the house is sealed well. That is fine by me.
My friend has an older house (built in 85 I think) and he was seeing $300-400 gas bills this winter. So far mine has been as high as $155
The garage is darn near 100% sealed. I was working on a tractor one night and closed the garage with fumes still in there. The next afternoon it was still smokey :wtf:
I have a garage filter machine to put up one of these days. In the summer I can open a window or the door, but when it's -30* out I will count on that more so.
walrus
Maine
Air to Air heat exchanger, the warm indoor air heats the cold clean make up air as its brought into the house. Sounds like you should have had one? Pretty tight house.
In colder climates you'll see more and more blower door tests as folks try to make there homes tighter. I doubt you can have a tight garage if you have overhead doors??
Frank Elson
Lancashire, UK
Originally Posted by tcianci View Post
...... why don't cha, skip the "analysis-paralysis" and have a good time.<<<
Blimey, seems to me you're the one up your own ***.
Some folks enjoy driving cars.
Some folks enjoy driving cars and fixing cars.
Some folks enjoy driving cars and fixing cars in a nice, dry and warm garage.
Some folks enjoy driving cars and fixing cars in a nice, dry and warm garage they built for themselves.
...and some of us enjoy reading about all of that.
Deal with it.
blazentrout
Grand Rapids, Mi
I dont post much, but i like this type of thread. If i'm going to do some thing, i'm going to do in to the best of my ability. I run on limited funds so i take things very seriously so i like to do things one time. Did i need the R38 walls or R60 in the roof of my barn, no but i was doing it once and only once and did not the "I wish" later. My barn is like a second home to me and if i do sell, I can say it was done right and could be used for anything from storage to the new biker club house.
Will I get the money ive put into it back out, no most likely not but its a hobbie to me and that is what makes it worth it to me.
ptschram
Churubusco, IN
Contractors are not at the bottom of the food chain and in fact we have more freedom to work for WHO we want when we want and IF we want than many other professions.
With the Tyvek, you probably wont even see the 20 year mark.
I sure want to know what part of the country you're in if you're able to maintain this attitude. Around here, contractors are shutting down and declaring bankruptcy daily.
I recently put a job out for bidding. I had my choice of contractors, everybody wanted the job. Unlike most in the general populace, I chose the high bidder as I had the most confidence in him. When the job is finished, I know I'll be pleased with his work.
As for Tyvek, as a "retired" environmental, health & safety engineer, my life has depended upon tyvek products on many occasions.
nate379
Palmer, AK
To get a 5 Star + rating yes. I talked to the head guy of the program and he said it's very difficult to get that rating on a house with no crawlspace as well... in his opinion it was not worth the cost of putting in that system as it may cost more than the benefits.
Insulated garage door that is sealed well. It's tight enough that you can tell when closing the people doors in the garage if a window or the vehicle door isn't open.
Mr. Welsh
I'm not sure I have any hobbies that don't involve a significant amount of research & planning. That's often more fun than anything else. And dreaming doesn't cost nearly so much as doing.
Ramblur
Central FLA
I must say I've enjoyed this thread,but I didn't build my shop for anyone else
but me. I've been through some real sh*tholes in my time,suffered well
ventilated places in sub freezing temps,lost a real cozy one to a fire,and
worked outside at different times for different stretches. I'll never be able
to duplicate the ambiance of the 1920's theater/shop either,but I'll never have to deal with the soft rain of asbestos from the ceiling every time you fired up an open headered engine or turned up the volume on the stack of amps a
bit too far. Yes when it came time to build my own it was only the finest
10" thick aac solid concrete block imported from Belgium. Thirteen years
later the only thing I would have changed is to have doubled the size.
BTW,the aac block came in $9K cheaper than standard cb between the
house and garage.
Guess I don't really recognize this "building too seriously". It surely
doesn't apply to mine.:moon:
T
tcianci
Walpole, Ma
Guys, This is great! it's one of the most lively threads on here in quite a while. One of the posts commented on how he agreed with some of the things I said but how I couldn't have communicated it in a worse way! He is probably right! Slick will probably never be one of my attributes.
As far as the Tyvek..I was not aware that there was a specific issue with the product as far as being used with cedar, although most all of the failures I have seen are with cedar. Some of the failures were with vinyl some were with pine. I had asked a rep from Tyvek about the moisture problem and he basically confirmed what I had been seeing without actually admitting it, after all it's his job to sell the stuff. I do recall reading an article in Fine Homebuilding that was written about cedar siding application. The author made note of the fact that he was using felt and not Tyvek and then he gave his reason, which had something to do with the jury still being "out" on the product. I have nearly every issue of FH since the publication started and I couldn't find the article again!.
In fairness to the product, it is a great air infiltration barrier. That's what it was designed to do. Add to that the ability to apply it to large areas of frame wall before the walls are stood, its' resistance to wind when only attached with conventional staples and it sounds like a winner. In that respect the product presents several advantages for the builder, but not necessarily the building. As stated before, I'm a remodeler, that means I take lots of houses apart in order to remodel them. I started seeing failures on projects that were barely 10-15 yrs old. Whether opening up a building to add on or simply doing maintenance, I found a common condition that the wall sheathing behind the Tyvek was usually waterlogged and often rotted. Is that a problem for because of the Tyvek or because water got behind the siding? I thought about this...but I was finding rotted sheathing in the middle of walls and such and the damage was always worse at the sheathing and face of the studs and then diminished as you moved toward the inside of the frame wall. This led to the conclusion that the moisture was more prevalent at the outer parts of the wall than the interior. The product was advertised as being able to stop air infiltration while allowing water vapor to go through, a good characteristic, if the source of the water vapor is the interior of the building. Building interiors are a source of moisture, bathing, cooking, breathing all generate moisture. Moisture wrecks the effectiveness of fiberglass insulation, hence the vapor barrier applied to the product or the poly sheet used over unfaced insulation. So the only conclusion I could arrive at is that the source of the moisture is weather related and the vapor gets through the house wrap. Now what if the moisture is the result of a breach in the sidewall material? Thats where my comment about "bandwidth" came from. No breaches in the sidewall and trim...no problem, maybe, maybe not. The realities of buildings are that they are seldom static, heat, cold, seismic activity, wind, rain snow, all take their toll on a structure. The breach is inevitable and it is subtle at first. Now what if the building was wrapped with a material that would protect the sheathing, and stop air infiltration as well? You have a building more tolerant to the inevitable. To take the stance that water should never get behind the the sidewall material is somewhat short sighted. It happens. Every time wind driven rain hits a piece of J channel it does a 180 and runs behind the siding. It gets in around window and door casings, why else then do we do these elaborate wraps on the sill surface and jack studs with felt or flashing tape. Why do some craftsmen fabricate copper flashing pans that install at the base of exterior doors. In fact one of the latest nifty products is a plastic system that is adjustable for width that forms a waterproof tray with a sloped floor to channel water away from the building frame at window and door openings. Water happens. Caulking can bite you in the backside as well, follow this... we make nice neat joints,caulk them, paint everything real pretty, looks great, right? Well go back to the part about buildings not being static. You get a failure somewhere in the caulk, you probably can't even see it. Why does the caulk fail? Most of the joints we caulk are too small for the caulking. In order for caulking to work, it needs to stay flexible AND adhere to both sides of the material comprising the joint. Every caulking material has a limit as to how far it will elongate when stressed. For any given joint, once the movement of the joint exceeds the elasticity of the caulking material, the caulking will pull away. All other things being equal, if you have a caulking material that can stretch 100%, an eighth inch joint could go to a quarter inch and be within the working limits of the material. A 1/32nd joint could go to a sixteenth before it lets go. Usually we don't end up with eighth inch gaffes that we bury in caulking, but the 1/32nd stuff? Sure! its common! Will a 1/32nd joint move enough to become a 1/16th joint? You bet. The caulk fails, water gets in, guess what, it goes somewhere else and can't get out...everything is caulked. Rot, mold etc is sure to follow. This is one of the reasons that Andersen specifies a quarter inch caulk joint between their window jambs and the exterior trim you add around the window. Now a quarter inch when doing exterior "finish" seems big enough to drive your truck through, but that's what they specify because they know the joint will not fail.
I sure upset a lot of folks who have embraced the new and "better". But remember that the Romans thought lead plumbing was the cats *** a few centuries ago.
I have no doubt as to the the energy efficiency of the buildings discussed here. The point I was trying to make is that there is more to a building than just what you spend on fuel. Sometimes, buildings are like Hot Rods, you modify the original design with a particular performance goal... and sure enough, your car is a rocket, but maybe it can't idle 10 minutes in city traffic without hurling antifreeze all over the pavement.
The structures we create today are subject to the same caveats. The degree to which the longevity and maintenance issues of any particular structure will be impacted is unknown. Rest assured we are building structures that are much more fussy as to what they will tolerate than even 20 years ago. Terms like "sick building syndrome" come to mind. Everything is so finely tuned with respect to the performance of certain aspects of the building that if anything gets out of whack, it can have extreme consequences both to the structure and its occupants. We now have to contend with blower door tests, dedicated make-up air systems, air to air heat exchangers, radon mitigation systems and the like. I am confident that over time, these devices will be robust and commonplace (not to mention only serviceable by qualified technicians). Some of the stuff that is new today will certainly benefit all of us, some of it just lines the pockets of the manufacturers, some of it will come back to haunt us.
So guys, build with wild abandon! The garage may be the "last frontier" for manhood in general.
e-tek
Saskatoon, SK
yes..everyone of em here in Richmond, underbuilt and overpriced.
You guys really got me on saying: "Ever see a million dollar home that was underbuilt?" !!:bounce:
But you have to know where I live to know what I meant!! In Saskatoon, SK, we have the most historically depressed real estate. Before last years market correction (and I mean we went UP!) a million dollar home here was RARE - and of the ones that did exist, they where generally VERY WELL BUILT!
I'm sure if I had said: "Have you ever seen a $100Million dollar home...", someone would have said the same thing - Even though I could be sure the guy saying it has NEVER been in a $100Million dollar home.:thumbup:
mmhouse
Desert Southwest
tcianci, your points are well taken.
I spent 30+ years in the building supply business and agree with much if not most of what you say.
New materials and building practices almost always introduce new and unanticipated problems. Unfortunately we typically learn about those problems only after the materials/practices have been in place for awhile and guys like you uncover them. Then we come up with solutions to mitigate the problems (along with the inevitable lawsuits) or we decide that the the material/practice wasn't such a good idea after all or it with a newer and 'better' one.
There is no question that moving toward more energy efficient structures has made them much less forgiving. Having spent a number of years in the industry in Alaska during the early formulation of standards and practices for "superinsulating" residential structures I witnessed many of the unintended consequences first-hand (actually, thanks to the Canadians who were a few years ahead of us we suffered many fewer headaches and setbacks that we would have without them). As homes became tighter and tighter problems, especially moisture related, would crop up and move around the structure from one weak link to the next.
But back to your initial point. If someone wants to spend his time and money obsessing over minutea then more power to him, especially if it provides him with enjoyment and satisfaction. Isn't that what d-i-y projects are usually all about anyway?
Oh....and thanks for your thought provoking post. :thumbup:
sberry
Brethren, Michigan
I agree this is the place for discussion, this is a busy site. Its one of the reasons I like it. There is something for everyone. Its also full of the hobby crowd, great. We all have our issues, I personally think Harleys, golf, cars and hi priced tools are a waster of money for the working crowd, but hey you can afford it go for it.
Shocker
Olympia, WA
Tcianci - Thanks for that detail account. I appreciate the info/insight on those failures you have seen.
ddawg16
S. California
Tcianci - :beer:
Your last post was much better.....
In all fairness I get the jest of what you are saying and do agree on some points......and no doubt some people take it to extreme.....have you seen the guy with the driveway that lifts up to expose 2 more Ferrari's underneath?
One observation I have made about contractors (and this is not intended as any reflection on you)...because it's their livelyhood, there is a fine balancing act between speed and quality.....the quality needs to be good enough so as to insure return business and not return to fix ......and get it done quickly so you can make money.....and making money is the primary reason your in the business....right? I don't think any of us work for the "love of the job".
Hence, the work may be correct, to design and to code....but not perfect....
A good example is one recent thread where the poster was asking what to do about how the rafters mated up to the ridge beam......gaps as much as 1/2". While it might be structurally sound.....I know that kind of sloppy work would make me an unhappy home owner....
It's kinda like the two guys who have perfect yards....one uses so many chemicals that a dog can't make it half way across the yard without dieing....the other guy buys spiders and laddy bugs to kill the bad insects 'naturally'.....same basic results....just getting there differently.
I think the next thread needs to be "What NOT to do"....and hopefully you will share with us those mistakes that you have seen....and keep responding to other posts.
Icy Mike
Alaska
I fiind it amazing what some guys think they "need". I have a two car garage that suits me fine and my wife is still able to park inside. Before we moved to Alaska we lived in Wisconsin and the garage at the house we owned there was actually an old ice house from the turn of the century. I REALLY miss that old garage. It had character. The walls were all tongue and grove, the slab was cracked and repaired (it was poured years after being built), and the best part was that it 'smelled' old. I used to love working in that garage late during the summer nights listening to the hum of the old knob and tube wiring. I also love old tools, but that is a different story...
Mike
T
tcianci
Walpole, Ma
Hey Shocker and Dawg ! Thanks for the post. Dawg, you hit the nail on the head as far as what drives somone in this business and if I gave the impression that code is good enough, I'm sorry. We have to meet all the criteria you stated and also be better than the next guy. That means better in the form of workmanship and in the form of conduct and respect for your customer. You don't bite the hand that feeds you.
Codes are designed so that the ensure the public health and safety while being broad enough to be fairly applied to any building situation. That is where knowing your stuff comes into play. There are numerous instances where things should be built "better" than code and other instances where exceeding it would not have any effect other than to stroke the ego of the contractor or owner. I say go for it if you want to. I also apologize fo being long winded but the detail of some of the issues discussed here calls for more than a 2 line shoot from the hip answer. After all somebody here may just decide to use the info and I would be really dissapointed in myself if I steer them wrong (spelling excepted!)
ironman2424
well i agree 100% with him. the majority has gotten so caught up in " my stuffs bigger and/or cost more than yours does" and my wife screws better than your wife but let me try yours out just to make sure. it's gotten just plain silly. everyones worried about being cold. Don't ya'll know what a coat is anymore. alot of you have more money to spend on **** but don't have the common sense GOD gave a goose. i see so much overkill just on foundations that it is ridiculous and a waste of materials and good labor. i've said it before on here that you act like your going to be driving a sherman tank up on your slabs but alot of them are 20x20, 20x24 ect. enough lighting to light up a baseball stadium. and enough insulation to make the roaches and rats comfortable year round. and your still never satisfied. what tv do you have and is your stereo bigger than mine is getting old in a hurry. be glad you even have a garage or if you don't yet maybe you will have soon but don't get caught up in the BS gotta haves that you really aint gotta have. im out for now.
ghnl
Mebane, NC
...the majority has gotten so caught up in " my stuffs bigger and/or cost more than yours does" and my wife screws better than your wife but let me try yours out just to make sure. it's gotten just plain silly.
That is using a rather broad (and offensive) brush.
im out for now.
Be careful the door doesn't hit your *** on the way out...
