kimokalihi
- Joined
- Mar 6, 2015
- Messages
- 33
Would one of those light up the entire garage? I'd rather have at least two to spread the light out better when I have a car in the garage working on it.This LED fixture is great for large garages, hangars, shops, etc. We will do lighting layouts for you also.
http://primelights.com/LED-6-Lamp-T8-Highbay-Fixture-120-Watts-PL-6HBLD120.htm
That post is spam and the completely wrong fixture for you application. If I had to guess, I'd say your ceiling is 9ft. You do not need fixtures with reflectors, nor do you want high lumen high bay fixtures. sailah did it right. Please take the time and review the Light Fixture Layout thread in my sig below. If you have specific fixture questions, please start your own thread. This thread is intended to provide up-to-date info on the best bang for the buck technology.Would one of those light up the entire garage? I'd rather have at least two to spread the light out better when I have a car in the garage working on it.
Updated Spread Sheet: Lighting System Comparison
Add James Industry LED Retrofit
Rem Obsolete Cree LED
Rem Obsolete Osram LED
Verify-update all links
I've been waiting for this particular James Industry lamp to be available for online purchase without the insane China shipping charges and now it is. Available at Shineretrofits for $12.99 ea. I've been testing their 18W version for the last 6 months without any issues. This is the beginning of the transition where LED becomes more cost effective than Fluorescent. If you factor in the Lumen per Watt efficacy, this lamp actually beats everything on the spreadsheet.
As discussed in other threads, avoid sharp point LED light source with the frosted lens option.
Not yet.Platonic Solid- Have you found a supplier of the james industry bulbs that doesn't have a minimum order of 30?
You are correct.Am I understanding correctly that these don't require a ballast?
Lastly, can you recommend a well built but affordable 4' fixture (with knock outs, surface mounted) that I could use with these bulbs?
I'd welcome any assistance in finding these as well. I can get enclosures quite cheap, but only in large 200-500 piece quantities.
All viable. That $15.96 Maxlite works after you rewire it (the picture doesn't match the advertised product), though the PLT @ $12.52 is still the price winner. I can't vouch for the quality of any of these things.Browsing around the supplier you linked to, I was looking at these -
http://www.shineretrofits.com/shop-...icient-light-fixtures/led-ready-fixtures.html
Nothing stands out to you there?
Note the features state: "Designed for LED Single Ended lamps". The James lamp is double ended.Why would you need to rewire these LED ready fixtures? I read through the spec sheets for the fixtures and the lamps, but didn't find much about the wiring.
MaxLite L18T8SE450 1,950 lm $16.90 = 115 LM / $1, 108 L/W.
Requires non-shunted lamp holders as both hot and neutral are connected to the same lamp holder.
No idea which is truly more common. Seems like a 50/50 mix to me.
You're absolutely right about now being a painful time to be making this decision. Soon you won't be asking LED or Fluorescent, but which LED. The choice will still be difficult.
Chadddada - Unknown. Feit does not provide IES files. Best guess is aim for 80,000 Lumens = 22 lights.
turtl631 - PLT 55027 2 lamp strip light 1000bulbs.com $12.52. These bulbs are really easy to wire. Just follow the diagram that is on the lamp.
Please see response #34 (linked) in Kevin54's lighting recommendation thread.Platonic Solid - Can these be surface mounted? Thanks, scheu
I am at a lighting crossroads with my 40' x 40' shop (1/2 of the shop has 14' ceilings the other 1/2 has 9'). It was built in '06 and I installed (13) 2 bulb 8' T12/HO's. I also have 2 HID (400w IIRC) in the 14' ceiling side (although the buzzing they produce drives me nuts). I am happy with the light the T12's are putting out.
I keep hearing the T12's are obsolete but yet they seem to be still producing the parts for them. Ballasts are still available as are the bulbs. I was at Home Depot last night and 90% of their bulb inventory was still T12's.
I am debating whether I should stock up on the T12 ballasts and bulbs since they still are readily available??? The ballasts I have been using are Phillips Advance ICN-25110-SC http://www.prolighting.com/icn-2s110-sc.html ). I will say I am not real satisfied with the light output of the last T12 bulbs I bought from Home Depot (Philips Alto F96T12/CW/HO https://www.1000bulbs.com/product/4672/FHO-096CW.html ) vs. the original bulbs I used ( http://www.gordonelectricsupply.com/index~text~27032~path~product~part~27032~ds~dept~process~search?gclid=CKP1ipeNmMgCFZKBfgodauYFxw ), though the specs are close.
Or should I start replacing the T12/HO fixtures (as the ballast go out) to T8/HO (although I did see in this thread the HO version of the T8 will be obsolete??) ballast/bulbs??
These are the ends my fixtures are using http://www.amazon.com/gp/product/B003GIS20S?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s01
Also I hear that the T5/HO produce even more light but I do not think my T12 fixtures will convert to T5's??
