Nortonscustom
- Joined
- Jun 5, 2008
- Messages
- 375
Ok
I'll bite
Here's mine. (sorry blurry pics on my phone)
3 Phase powered by a .55kw motor & angle drive reduction box (22 rpm)
I have wired up a VFD so it has forwards, reverse & speed control in both directions.
I programed it to ramp up to the set speed, but to stop dead as soon as I take my foot off the pedal.
Yes, a pedal to start & stop, that way all hands free opperation.
I can inch it ever so slowly with the pedal which give me a lot of control.
I wouldn't be with out it
Damn, that's seriously stiff! While you were building in all that stiffness, why didn't you make a deeper throat? I stiffened mine up like most others have done and powered it with a HF 12v winch but the only thing I miss is the throat to get to the center of the floorboards I need to make.Ok
I'll bite
Jim
If memory serves, I used a 1 1/4" bore sprocket from Surplus Center https://www.surpluscenter.com/sort.asp?UID=2009062210215924&catname=powerTrans&keyword=PH40That is sooooo cool. Now you have me all jacked up to improve mine. Jim, do you have any pictures of the HF winch setup?
1) EM008 mens shoes nike air max + 2009 retro running trainers Here is a pair of men's nike air max shoes in black and red.The Air Max+ 2009 is an innovative sneaker that provides comfort, support, and stability. The extremely light upper is constructed with Flywire technology that uses strategically placed nylon filaments to comfortably hold the foot in place. They have full-length Max Air unit for maximum cushioning and it allows for a smoother, more natural range of motion. Plus, the Air Max+ 2009 contains a Nike+ pocket under the sockliner that "talks" to your iPod (Nike+iPod Sport Kit required).Get around in comfort and style with this sleek running-inspired shoes. 2) EM001 mens shoes nike air max + 2009 retro running trainers Here is a pair of men's nike air max shoes in gray and black.The Air Max+ 2009 is an innovative sneaker that provides comfort, support, and stability. The extremely light upper is constructed with Flywire technology that uses strategically placed nylon filaments to comfortably hold the foot in place. They have full-length Max Air unit for maximum cushioning and it allows for a smoother, more natural range of motion. Plus, the Air Max+ 2009 contains a Nike+ pocket under the sockliner that "talks" to your iPod (Nike+iPod Sport Kit required).Get around in comfort and style with this sleek running-inspired shoes. 3) EM006 mens shoes nike air max + 2009 retro running trainers Here is a pair of men's nike air max shoes in black and gold.The Air Max+ 2009 is an innovative sneaker that provides comfort, support, and stability. The extremely light upper is constructed with Flywire technology that uses strategically placed nylon filaments to comfortably hold the foot in place. They have full-length Max Air unit for maximum cushioning and it allows for a smoother, more natural range of motion. Plus, the Air Max+ 2009 contains a Nike+ pocket under the sockliner that "talks" to your iPod (Nike+iPod Sport Kit required).Get around in comfort and style with this sleek running-inspired shoes. 4) EM007 mens shoes nike air max + 2009 retro running trainers Here is a pair of men's nike air max shoes in black and gray.The nike Air Max+ 2009 is an innovative sneaker that provides comfort, support, and stability. The extremely light upper is constructed with Flywire technology that uses strategically placed nylon filaments to comfortably hold the foot in place. They have full-length Max Air unit for maximum cushioning and it allows for a smoother, more natural range of motion. Plus, the Air Max+ 2009 contains a Nike+ pocket under the sockliner that "talks" to your iPod (Nike+iPod Sport Kit required).Get around in comfort and style with this sleek running-inspired shoes.
on the turned down cable spool. The release lever allows the motor to be disconnected and the steering wheel attached to turn by hand. I find it easier to do straigh runs on the motor and then use the handwheel to go around tight corners. I run it from one of the jump start kits that HF sells. Runs a long time on a charge.
The sprocket ratio is 15t - 29t and it gives an no load speed of 17 rpm. I find that it is easier to do straight or slightly curving sections at a faster speed to avoid wandering. Here is the HF winch http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=92860Do you happen to remeber what winch it was from HF. How may RPM do you think it does. I trying to get something in the range of 3- 10 rpm without having to have a huge gear on it.
