Do people usually hold impact sockets like this?
hautpot
California
I was told to NOT do this for safety, but was I told wrong?
ovrrdrive
Central Florida
There's no need to hold it like that when it's running as it doesn't do any good and there are at least a few rare instances where it could lead to damage to your hand. Where that comes from is people put a hand on the socket to help seat it on the nut. Especially with a 6 point impact socket it can be difficult to line it up to the nut without using a hand to assist. Once it's on there though I take that hand off and put it on the gun.
If the socket were to come apart while spinning at high speed it could take off a finger. It would be a one in a million situation (assuming you're using the correct sockets) but possible.
H
hautpot
California
That was my concern with the socket becoming a projectile. Now it sounds like nothing to worry about as long as one doesn't use really worn out sockets or chrome hand sockets.
Rookie2
Western Pa.
Even a burr on the outer profiile of the socket could rip a nice gash in your hand once the fastener starts spinning. Yep dont do that and wear your safety glasses using power tools and around people using power tools. Eye injuries are frighteningly common.
I've had peeling chrome slice a finger or two ,slow down and think !
dlcwent
Member Emeritus
coastal maine
I would agree with every post so far. I think he is just lining up the socket with the fastener. ..........SAFTEY IS NO ACCIDENT.:eyecrazy:
shamrock12
South Dakota
I do that quite often. Doing so help keep the impact gun aligned linearly to the stud/nut from flopping around. Also to catch the bolt/nut from falling down and disappearing.
Marc Benjamin
Napa California
He's just starting to line that up since he's holding it tightly.
Now, I do loosely keep my gloved hand in that position to brace and catch the nut from flying once it comes of.
redwrench60
East Tennessee
You guys do know that's a staged photo for demonstration purposes and not real work going on.....right? Is that not IR advertising?
shoggoth80
Seattle
Oof! That soldering iron method would huuurt.
As far as the impact goes... that is either a very, very worn impact (I've seen them worn grey. My 21mm is almost there), or it isn't an impact at all, and therefore risky in and of itself. Otherwise, I see someone indexing the socket to the fastener. Once on, I move my hand back to the top of the gun. When the fastener is either almost off, or spun off, I mopve my hand back forward to catch it.
It's almost like the H&K catalog that had pictures of the rounds backwards in the magazine...
Zrexxer
Pflugerville, TX
You might get away with the impact wrench indefinitely, but you'd learn the error of your ways the first time with the soldering iron!
APEowner
Sunny, New Mexico
I can't tell you if it's a good idea or not but I can tell you that I've been doing that with impact sockets for over 30 years. I won't do it with a chrome one and I don't have burrs on my sockets.
mailpup
Los Angeles
Of course you shouldn't hold the socket that way and one should use an impact socket instead of a chrome socket but, that said, I'm sure people do it all the time just the same. I think using a chrome socket for impact purposes is especially common although not advisable.
soj
North Georgia
I would NEVER hold a soldering iron that way, her hand is WAY too far from the tip for proper control. You just have to learn to **** it up!
GRX
MD
Besides what has already been said ... I have seen guys hold them like that if the socket retainer ring is missing or has been removed.
iScream
Middle TN
Do you guys usually hold a soldering iron like this? [
Sent from my SM-G920V using Tapatalk
Of course, and whenever I buy a new motherboard I randomly find some capacitor leg to de-solder while resting the hot iron on the PCIE slot. Safety glasses help keep the smoke from burning plastic and flesh out of your eyes.
rodsnratfinks
California
I knew it! I've been doing it wrong all along.
Shadowdog500
Down the shore
Do whatever you want, but I wouldn't be hanging onto a rotating socket. I still trying to figure out why you think you need to do this. Gloves will only catch into the socket and twist your hand around it.
Whatever you do, don't use your finger to remove a nut from the socket on an air gun..
Chris
defektes
Arizona
Chris
All I could say when I saw that was "HOLY ****!"
bbs lm-r
Chris
http://i.imgur.com/Ou9f813.jpg
Would it kill you to post some kind of warning before you post something like that...
