so i've begun to wire in some extra outlets in my attached garage. i've already added outlets to the side that's unfinished, and now i need to start the side that leads into the house.
since the side against the house has drywall covering the studs i've decided i want to go surface mount running conduit to a four outlet gang box using 1/2" emt. before i do this i've got a few questions.
1st is...i know i should ground the emt, but how do i go about this? i'll have 12/2 romex from the breaker to the outlet. i'm pretty sure i should use a 12ga green ground wire too. where to i connect this in the gang box, and in the main panel? the emt will only be running from the breaker wall to the gang box with a few 90* bends. it will not be connected to the breaker box.
2nd ?? is...the emt will be running/touching under flex conduit. it will also be running/maybe touching my a/c vent system since it sits close to the wall the conduit will be running along. will this cause any additional problems?
3rd?? is...am i better off just running pvc along the wall instead of emt? i'd rather go emt but will go pvc if it's safer.
thanks!
thanks!
