93" fiberglass insulation
gogolf0401
West central MN
For those of you with a pole building with posts 8' OC... I know there are places that sell 93" wide fiberglass rolls which will fit perfectly between posts at 8' OC. Where can you buy this stuff? How much did you pay?
kj_mustang
Harrisonburg, VA
Look at local building and ag supply companies. I found plastic faced R-8 8' wide rolls at a local building supply company that also builds pole buildings.
Diesel Dan
TN
Johns manville PEBS blanket.
Bought mine through a Morton builders, unfaced R19 6"x93"x 40' rolls about $130 last year.
Part number : P19925
theoldwizard1
SE MI
If you are planning on putting up interior wall board of some kind, here is another route entirely.
Hire a spray foam crew to do all the seams and between the posts and the tin. Make sure they get all of the corners well. You only need 1-2" of foam. Then spray "wet" cellulose and cover with wall board. Or hang the wall board and blow in dry cellulose or fiberglass. Probably cheaper and faster than trying to hang such a big piece of fiberglass roll/batt.
Diesel Dan
TN
One person can hang 14' long batts, with a broken rib.
Ask me how I know.:(
