shopping for a locking flex ratchet
missouri
I have the Pittsburgh pro 3/8 long flex head ratchet from hf and it's actually alright until the head gets loose and you can't tighten it up anymore. I use it on a daily basis and it's really it's starting to piss me off. So I've set out to buy a better quality locking flex ratchet. I've been happy with some gearwrench tools that I've bought. Considered the matcos but I've tried them out before and they seem decent but would put a decent dent in the wallet. Im not one to worry about COO, if the tool works the way it's supposed to I don't care where it came from. Recommendations?
fivespdcat
If you liked the Matco, then the natural choice is the Armstrong Maxx ratchet. A lot cheaper and basically the same ratchet.
Fedwrench
Valley of the sun
Avoiding the tool truck brands, here are three choices:
Armstrong MAXX locking flexhead ratchet very similar to Matco.
http://www.harryepstein.com/index.php/3-8-drive-armstrong-flex-ratchet-88-tooth.html
Gearwrench locking flexhead ratchet. very similar to Armstrong and Matco but, imported. find the best price on Ebay or amazon available with or without comfort grip. comfort grip model longer.
http://www.gearwrench.com/gearwrench_news_release
Lastly, Carlyle from Napa
http://www.napaonline.com/Catalog/C...-Flex-Locking-3-8-/_/R-CHQR38LFLQR_0438142640
Hiball
Missery
Unless your needing 24" or need a comfort grip I would go with the Armstrong over the GW, I own the 24" GW and the locking mechanism isn't near as tight as the Armstong/matco version.
missouri
I forgot to add that I like the longer flex ratchets around the 14 inch mark. I took a look at the Armstrong look like a good ratchet for a fair price but they're 11.5 inches. Does Armstrong make a cushion grip model that's maybe a but longer?
Fedwrench
Valley of the sun
Nope. The Gearwrench locking flex head with comfort grip would be the longest one of the three I posted.
Tim37
I was once a big fan of the Marco flexheads with the detents but the so dual 80s have me now. If u use them daily I would buy a higher end ratchet its worth the money. Also the so non locking have a spring in the handle that holds tention so they don't get floppy like some of the cheaper brands
AmishFury
Is the matco longer than the Armstrong?
the matco is listed as 12" overall length but i find what matco's site lists for overall length and actual overall length are a bit different... my 24" locking flex 1/2" drive (chrome handle) is closer to 27" my 11" fixed head 3/8" drive (comfort grip) is right at 12"
their site lists the overall length for the chrome and comfort grips as the same... can't tell you if there is any additional length from the grip handles myself as i've never seen the 2 side by side
i will say that the locking flex 3/8" from snap-on is listed on their site as less than 12" and the non-locking dual 80 long handle flex with comfort grip (FHLF80) measures out just under 14" overall
rdog422
montgomery
these are great
https://www.pricefalls.com/product/...LLSv_7FCInnuXCveiE6zEhR5MkqcEi5uAsRoCaLnw_wcB
maxpower_hd
Massachusetts
This is why I ended up with the GW myself. I've had it for about two months and use it all the time. So far so good. I don't really care about the cushion grip but the length is what I like. And the head is pretty narrow so it fits in a lot of places my Crapsman one would not. And the higher tooth count is a huge plus in tight areas as well.
Dave455
Sussex, England
KoKen are very good, especially for more specialised things like locking flex ratchets!
Their ratchet mechanism is very tough, and they offer several styles of handle - probably more variations than Snap On!
Prices are reasonable too! Probably the best value out there at the mo!
PJNJ
Iowa
I have the Armstrong and it is very good. I would have bought it sooner if I knew how good it is.
:beer:
mcmtech
New Orleans, La
I've got the gearwrench soft handles ones. They don't lock, but the detents work well enough. The length, thin head profile and the fact they aren't quick release with a button are very nice. High tooth count as well. Use them daily professionally.
Wakefield
Arlington VA (but would like to get out to country
Does the HF have a spring washer inside the fork aside the works? Can it be replaced with a stiff lockwasher from a hardware store? (If trying to take the joint apart put it inside of a Baggie or piece of clear wrap as things might jump out when you take it apart after removing the bolt.
