Chain Drive Extensions, Does anyone else have one?
Jbullfrog
Avoca, Iowa
I have two Blue-Point Chain Drive offset extentions that are priceless when needed. The 1/4" drive has JWT1 on the back and Blue-Point USA PAT on the other side. It is 7-1/2" from the female square to the male square drive. 1 also have a 3/8" drive that I use for starter bolts on Ford tractors.
Has anyone else ever seen one of these? Are they still available? Who actually made them for Snap-On?
chad s
Baltimore, MD
wow, id like to find one of those in 3/8 drive. Just checked ebay, couldnt find anything. Perhaps there is another term for them besides a chain drive extension?
J
Jbullfrog
Avoca, Iowa
Snap-On had them for a year or two, but they never made the catalog. I saw them on the truck in 2000. Since I got mine 4 or 5 years ago, I haven't seen another one any where.
Uncle Buck
Kansas
Man, the ultimate specialty ratchet! that is the first one I have ever seen, I would buy one of those in a heartbeat! I wish those were still available, I would even go as far as to buy from Snap-On:wtf: to get my mitts on one of those!:spit:
Rickster
SE PA
That Productive Tool website is pretty cool, but where are they hiding the prices? I often see Williams stuff at garage sales, I'll have to start picking it up!
Uncle Buck
Kansas
I have quite a few Williams tools, if you have been passing on them, you have been missin the boat. Williams tools are good stuff, and were, long before they got hooked up with Snap-On!:beer:
Major Ramifications
River Ridge, Louisiana
OK, call me stupid, but why is it called a chain drive wrench?
It looks like an old Blackhawk ratchet I have, where you push the square drive part through to the other side to change direction.
J
Jbullfrog
Avoca, Iowa
I call it that because it has a chain inside that connects the two ends. The female square drive rotates the male square drive that is 7-1/2" away. You put your ratchet in the square drive of the one end and turn the socket attached to the other end. One common application is removing fan bolts. Where you don't have access to directly swing a ratchet, but with this offset, you can use an extention through the blades and swing the ratchet behind the fan on one side.
Major Ramifications
Now I get it! Damn, that is COOL! I might have to be on the lookout for one, just for the hell of it.
Danglerb
SoCal
Funny I was looking at those last night, the guy is local to me and has a rubbermaid looking service cart for pickup only I am thinking about bidding on, so I checked the rest of his listings. He calls it a torque multipler, so is it one to one or geared down? A chain inside or a series of gears?
J
Jbullfrog
Avoca, Iowa
They have no multiplication involved. There is a sprocket at both ends with a chain connecting them. It is a 1:1 ratio. It simply offsets your drive tool 5-6" from what you have the socket on and or reverses the orientation. They are very usefull for fan bolts on tractors where you have to reach into the shroud to remove the bolts.
ColdDuckTime
Now there's a good use...fan bolts. I always have hated how I manage to cut myself on blades, shrouds, and radiator fins.
The next logical step is to hook an impact wrench on one of those babies.
J
Jbullfrog
Avoca, Iowa
I dont know. They are hard to find, and no longer made, and probably not designed for impacting. I wouldnt want to risk wrecking one with an impact.
I have the sticker label from both of mine that state "Do not exceed 45lb/ft of torque and not for impact use. I have used them with an air ratchet from time to time.
The other place I use them is for the inside bolt on Ford tractor starters. You can see it with a mirror, and have to have a wobble socket and 10" extention which gets you just short of the fuel filters.
Uncle Buck
Kansas
Dragging up this old thread, who here has these devices? I finally found a set in a pawn shop for $50 for the pair and pounced on them. I still have not needed them yet though.
J
Jbullfrog
Avoca, Iowa
You will be happy that you have them someday. I used mine for motor mounts on a rear tine tiller a couple weeks ago.
Blacknwhitepit
Eastern Tennessee
Still have mine!!!
-BWP
Uncle Buck
Kansas
No doubt I will, I figure them for that tool that will save my hiney on some job at some point in time! :thumbup:
EDIT: What the heck! BWP has two of the 3/8" drives!
BTW: Did the ones you guys bought still have the stickers on them cautioning against using them beyond a certain torque value? I do not recall, but that torque was not much, something like 50-70 foot lbs or so as I recall.
^^^^^^^^^Never mind I just noticed BWP has his labels, and showed them.
J
Jbullfrog
Avoca, Iowa
I usually fill a measuring cup with 20w and submerge the end with the oil hole and then turn the other end to lube the chain at least a couple times a year.
Diesel-Mech
Kansas
Digging this old thread back up since I finally have a set of these.
These things are awesome, its a shame they aren't more common.
superautobacs
Vancouver, BC
There was an offering in the past, in Japan. Produced by a company called Merry. It was called the Barrier Wrench. They had a patent that covered US, West Germany, Japan and Korea.
Check the attachment titles for more informantion.
