CooperS7777
For those of you with both, how did you install them?
I'm leaning towards installing the cabinets over the flooring for a couple of reasons;
1) While my slab does not have water intrusion, it does pick the cabinets up a hair and provide some space between the two.
2) I think it will provide a cleaner, more finished look.
The concerns I have are:
1) Does the flooring make the cabinets any more difficult to level, or is the process still the same? I will be using my cabinets as a work bench also, so level is more important than if they were stand alone.
2) Does the flooring make fastening to the slab any more difficult? Do you still use a standard concrete anchor? Shouldered anchor? Is there any danger of creating a low spot on the cabinet/tile by anchoring through the tile?
Thanks in advance!
-Coop
Thanks in advance!
-Coop
