OSB for ceiling
al704
tried to search this but for some reason it won't work. Getting ready to install the 716 OSB ceiling and have some questions. Screws or nails, I have access to a framing nail gun and 3 1/2" nails but wondering if screws would hold better. I will be using blown insulation, do I need a vapor barrier between the OSB and insulation?
k-os
WI
Location will help people answer questions about the insulation. I'm in Wisconsin and when I sheet my ceiling I put up vapor barrier on the rafters then screwed the OSB in.
ddawg16
S. California
Personally, I'd use 5/8" drywall before I used OSB. If you have a fire, well, get out fast.
I wouldn't use a vapor barrier on the ceiling. All it will really do is trap the moisture in the wood. Most of your moisture will come from inside.
Screw or nail is fine. Nails are faster...but screws make it easier to remove
What is your joist spacing?
Slowgsr
Southern ontario
You won't need 3 1/2" nails, way too long. If your not perfectly centre of the truss your going to start splitting them - not good.
Vapor barrier between osb and insulation - yes
I'd use some 2" - 2 1/2 coil nails, that's what I used when I did my 1x4 strapping prior to drywall on the ceiling since trusses were 24" and I'd rather have a wider screwing strip at 16 oc
I'd never cover the walls of my garage with anything that burns, not sure why people do? If your anti drywall for some strange reason (especially for a building with heat/air) then I'd go metal.
JCQuick
Apopka Fla.
I like that logic as I considered OSB over drywall for my build
Kevin54
MEMBER EMERITUS
Urbana, Ohio
By the time the fire gets to the ceiling, the place is going to be pretty much engulfed anyways. OSB will burn fast and hot, and chances are if you are putting it on the ceiling, you have it on the walls. Using that logic, most fires start at the bottom of the structure. You'd be better off drywalling the walls instead of OSB on them. The drywall may be enough to hinder a fire until it can be put out. By the time the flame hits the ceiling......let'er burn
fteufert
Near Scranton, PA
As someone who had a garage fire, the type of wall covering made no difference. The contents burn, and all the wall covering does is keep the heat in. 80+ year old framing is no match for the heat generated by burning plastic, oil, cans of carburetor cleaner, etc. I was lucky my car with 1/8 of a tank of gas didn't blow, or the small propane cylinders for plumbing. Trust me, a fully engulfed garage is better than a partial burn when it comes to insurance.
My new garage has 7/16 OSB on the walls and ceiling, and if it ever burns again, so be it.
strutaeng
Dallas, TX
I'm building a room in my remodeling home and decided to retrofit a bedroom into a "high-wind resisting room." My wife is paranoid about tornadoes!
Among other things, I'm using plywood for walls and ceilings with a very tight nail spacing using 2 3/8" ring shank pneumatic nails. I'm then installing regular 1/2" drywall over that.
I was initially concerned about the fire rating, but I couldn't find any literature about the fire rating on 1/2" drywall. I did find a resource that stated something like 15 minutes! Anyways, unless you are using 5/8" Type X gypsum board required by your AHJ, I'm convinced 1/2" gypsum board provides little to no better "rating" than regular wood panels.
What's more, a fire rating is usually an assembly rating, meaning firestop at penetrations, etc., which is typically never seen in single-family construction in my neck of the woods (North Texas).
I hope this helps.
Falcon67
Merkel, TX
I used 1 5/8" decking screws. A lot of them. No issues and now that a lift is in the plans, easy pie removing sections as needed for clearance and reconfiguration. Same with the OSB on the walls - if adding a plug or doing other mods, I just remove the panel in question.
As for fire - keep the cell handy and plenty of extinguishers - 5 lb if possible in handy places. If you can't snuff it, get the hell out. I have so much combustible material in the shop - race fuel, brake cleaner, carb, cleaner, paint supplies, etc - it doesn't make a s&*t what's on the walls. If the whole thing was metal it'd still burn to a warped mess or blow up. IMHO "OSB is a fire hazard" is a red herring, same as "if OSB get's wet it's junk".
maxpower_hd
Massachusetts
The fire ratings may vary but I have been told the following:
1/2 Drywall = 30 minutes
5/8 Drywall = 60 minutes
19/32 OSB (roughly 1/2") = 14 minutes
I have always been told to use drywall for any type of fire protection. You are required to use 5/8" drywall between a garage and any occupied space here.
The cost is pretty close so I don't really know what the benefit of using OSB over drywall is. It burns easier, it's about the same price within a dollar or less a sheet, It's harder to prime and paint, it's harder to finish if you want a smooth look, etc. I would just use drywall myself.
