Adding Solberg Silencer to the Husky 60 Gallon Air Compressor
ovrrdrive
Central Florida
After seeing them talked about in several posts on this board I decided to add a Solberg silencer to my Husky 60 (from HD). This compressor actually has 2 intake ports behind a foam filter that is held in place by a plate instead of having threaded holes like most other units I've seen so some light fab was in order.
I saw a link to this filter posted in one of the threads and ordered one without looking at it very closely. Turns out it is only rated for around 12cfm flow and since my compressor puts out almost that much at 90psi I figured I'd change my design a little and run two of them instead of just one and placed the order for the second unit (thans for Amazon Prime...).
http://www.amazon.com/dp/B00H43L16I/?tag=atomicindus08-20
I had some 1.25" square tube so I cut a thin piece with a small shoulder off the end of one, trimmed and shaped it down and made a plate to fit the opening where the filter sat. No pics of the fab so bear with me. I looked for a bung that would let me screw in a few 90 degree elbows but HD didn't have anything big enough so I finally settled on a threaded extension about 2.5" long and just cut it in half and welded one on each intake hole. After it was welded up I used a die grinder to match the hole to the pipe perfectly with a slight taper. After I was happy with that I screwed everything together and gave it a quick shot of rustoleum black and let it dry overnight. A little speaker gasket on one end and I mounted it up.
It looks as good as I guess it could given the material I used and definitely sounds better but it is still pretty loud. I shot a little cell phone video of it but it's hard to pick up the difference in loudness because the phone balances the audio, but you can hear the change in pitch as the intake is almost completely silenced now so all you hear is the motor and compressor.
Overall it was simple and definitely does make a difference. I'm pretty new to the welder and always looking for projects so it was a fun and simple project. I probably could have gotten by with one of the larger Solbergs but I kind of like the look of the dual. Here's a quick vid of about 15 seconds each way for comparison.
Whiskeymike
Austin, TX
Very nice, thanks for sharing. I have the same compressor. If you would have gotten a different model, would it still have required the fab?
kunkernator
US of A
I have the same filter on an older Husky 60 gallon. It only has one intake port. Now that i read the specs, i think one filter may be choking it (i didnt put it on, previous owner did).
O
ovrrdrive
Central Florida
Unless I missed it they don't have one that would be a direct fit for this model compressor. It kind of surprised me too seeing as how many of these are out there. If I had the bigger one I would have just blocked off the intake port and drilled a hole in the top plate for it. Since I already had one on the way I just went with it.
I wasn't sure if the flow spec applied to the intake port where the compressor is sucking in or not. It was easier to just use two than to figure it out.
How did he mount it on yours?
kunkernator
US of A
Mine just has a 1/2" female pipe thread right in to the head. So, just screwed it right in.
Markfothebeast
I commented on the Youtube video of your compressor. Had to join to see the photos. I have the same unit. It is incredibly loud. My concern is that the stock filter/muffler is choking the pump air intake. 12 minutes of run time causes the air exhaust line and cylinder head output area to get around 315 degrees. I am currently building a 1/2" copper line cooler with water filter to hopefully drop the exhaust line temps. I was burnt by the piping it was so incredibly hot. Your mod might help reduce the pumps temps also.
O
ovrrdrive
Central Florida
While you're here search around for air compressor mods... There are a ton of threads and ideas for you on the forum.
My compressor is still loud but as you heard in the video the pitch of the noise changed a lot and it isn't nearly as obnoxious or fatiguing as it was. It was well worth the time it took to do it.
Oh and the head and tubes on my get really hot too. If you want to bring that down look to add an intercooler to it between the head and the tank. I've seen some that get it to almost ambient before ti goes in the tank. removes a ton of moisture too.
sberry
Brethren, Michigan
Its work and expense to gain only a little. A simple sheet baffle in front of the unit would help a lot and depending on climate using a hose to bring in outside air would help a lot, an insulated one similar to a dryer hose. My shop is cool and usually dry except for a bit in the summer and I dont use it a lot then but could still add an intake dampener and may change my enclosure for the main. At one point I had it insulated better but this aint bad.
Breaker is off to the blue spare/demand unit. I so rarely need it with lotso tank, am done with most chores before supply is an issue.
Markfothebeast
I'm considering plumbing the intake with 3/4" copper with threaded adapters and running the piping directly into the garage rafters. I could probably use some type of threaded generic lawnmower air filter housing that I can pick up at the hardware store. This should transfer the intake and valve noise elsewhere.
tenexotic
home
i have the same compressor and i hate how loud it is i deffinetly have to do this also I am on the 3rd electric motor because overheating has anyone had any experience with this? thanks
R_einan
Eastern WA
I have an industrial air 60g compressor that is essentially the same as the huskey. I did a similar job using a steel plate drilled and tapped with some 3/4 black iron fittings and some filters I got on the cheap. Really helped mine, I’d say a good 30% reduction in noise. Enough you can stand next to it running and carry a conversation without having to raise you voice. Also doesn’t make you jump when it kicks on.
Motocrisis
Ontario
R einan
That looks great, I recently bought the same thing but a sanborn. I am going to do something similar.
danielbuck
I've done something very similar to mine, except I put hoses on mine and mounted the filters way up into the roof, keeps it a lot quieter.
Motocrisis
Ontario
Excellent improvement, still loud like any other compressor but much less obnoxious
