Home Depot Clearance Thread 2015
Status
Not open for further replies.
drwheels
okla. city ok
Dang, I thought I lucked out as one of the stores around me was showing 3 pressure washers in stock. I searched the store up and down and couldn't find any of them!
Did you look in the outdoor garden area? One area store has chainsaws,lawnmowers.generators and pressure washers outside. Some of it is used or reconditioned.
Spn1025
New Hampshire
That goes for a lot of things. Some of you mentioned before that you couldn't find tool boxes.. Make sure you check the outside garden area also. They store a lot of bulky stuff out there. Hopefully it isn't nasty from bird ****
rpearlberg
Fairfield, CT
Finally found one CS-330T. It was a display with no box, no gas cap, no chain, and I"m not sure what else it should come with. The guy that helped me threw in a chain and said to call/email Echo and ask for a gas cap. What else usually comes with the chainsaw?
Long time reader, I feel a need to give back for all the deals I have gotten..
I spend $.25 tonight.
SKUs are as follows:
1000-024-403 15 ft black dual lock
1000-024-401 15 ft clear dual lock
1000-024-372 4 ft black dual lock
1000-024-368 dual lock strips
1000-008-388 command blue wire hook
1000-008-383 command purple wire hook (not 100% sure about this sku pic is blurry)
0000-581-456 command large cord organizer
0000-992-685 command picture hanging strips
0000-339-999 energizer led caplight
They were all just waiting at the end cap...
honda pc
did you get it for a PENNY...
you're missing the owner's manual and safety manual....spark plug tool, tip guard, and echo gas mix.. quick start guide...
here's a pic...
Spn1025
New Hampshire
A small bottle of some fluid... Forget if it's fuel mixture oil or bar/chain oil. Lol not a big deal. I think there's some wrench?
Edit.. Nvm see above
rpearlberg
Fairfield, CT
here's a pic...
Thank you for this! No, it was $65.03. They threw in a chain and hopefully I can get the other parts...
Not the greatest deal, but still a good price for this saw.
UPDATE: Spoke to Echo and they are sending me the oil cap and any other accessories that should have come with it (manual, oil mix, tool, etc).
iSP
06GMC5.3L-
I going to pm you for access to the spreadsheet. I have a item to add to it which I haven't seen posted.
Thanks!
Spn1025
New Hampshire
Does that store have a tool rental? I was told by an employee that they have to sell it in working condition. I was gonna buy a Bostitch coil nailer a few months ago, display model that was missing parts. He said to take it to tool rental so they can fix it. Tool rental should have your gas cap I would imagine. They do repairs on Echo products
rpearlberg
Fairfield, CT
Interesting. Let me see what echo says and then I can try tool rental.
chrisexv6
CT
There should also be a slightly used old school hockey mask and a tape of eerie music to play while you sneak up on someone.
Good deal! Which store did you eventually find it at?
rpearlberg
Fairfield, CT
Fairfield. It was on the shelf with the others, just had a yellow tag marked at $246 (down from $259).
SRMX
My brother-in-law went to a store this morning that said there were 4 pressure washers in stock. He looked the whole store over (for a solid hour) and they were nowhere to be found. Employee confirmed the price dropped to $28 that morning. Seems like 4 units are a lot to loose track of. Hmmmm. This was in Arizona.
loranger
DFW, TX
I thought the same thing. When I looked from another store, the one with the pressure washers showed 2 in stock. When I checked the computer in that store, it showed 3. I checked on top all over the store including the garden center and could not find them. I had the same thing happen with the Echo blowers. One store showed 2 from an outside computer and 3 in the store. Could not find any of them.
taylors tools
I saw a cart full of these and didnt give them a second look, came home saw this and then went back and they were gone... it killed me
duddly
Southern MD
searched capital heights md for an hour looking for their 3 pressure washers. There is even a pallet up in aisle 51 that we pulled down because it had the sku on it, but when we got it down there were none on there (I confirmed). they put it back up without crossing out the bad sku. I did get a display model for $7 - missing the spark plug, oil cap, and the tips, but it definitely has never been run. searched outdoors, and the whole rest of the store. The fellow who helped me look was awesome.
stage20
pcola FL
i know i should know this, but a product ending in .06 cent stay at that price? im looking at a few things and i want them to drop, just not sure the next step in price or when.
Mrbossman
Can we get some pics of the items? Most cant be pulled up on HD site. Just trying to see what I am looking for.
Thanks
honda pc
To anybody in San diego,,,CA ....San Marcos location---Tool Rental section-- has a echo cs330t in a box, used or fixed by HD...with a yellow tag price of $180...with a new sku(wrong) number...and also the clearance sku number(correct) in small print on bottom left of label...
But the other side of box has the right sku 854531 which is correct number for $65.03 clearance price.... I left it there because I already got their last 2 new units on this past Sunday....so it might still be there...????
To get that echo saw at $65 clearance price would require convincing them that yellow label sku ## is wrong and price is wrong....You would have to ask them to ring it up at the old sku 854531 on the side of box....and maybe get some disccount from $65..... but it would be some working with a manager or somebody in power....
the saw looked good, used chain and wasn't bad.... here is some pics of it I took...
and it might still be there...... give it a shot if you are close and good luck..
stevep500
DFW
Anyone want a new Husky 48" wide black and grey floor cabinet--cheap from the HD Plano, TX clearance section? I bought both units I listed here a few days ago. I screwed up. One fits my shop. The other one doesn't. The depth is fine, I just forgot to take into account the room needed for the door swing (dummy :eyecrazy:). The SKU is 236968 and is on HD's web site at http://www.homedepot.com/p/Husky-48-in-Floor-Cabinet-48FC01BP-THD/202600940?keyword=236968.
It cost me $102.87. It is built and ready to go or I can disassemble it if you want. I also still have the box.
So, if you are in the DFW area this is a great deal. If no one wants it, I'll just take it back to HD or sell it on Craigslist.
Steve
Spn1025
New Hampshire
Click the link in my signature please. It will answer all of your questions.
06GMC5.3L
Just take it to SCO and scan the bar code. Done...
Sent from my iPhone using Tapatalk.
06GMC5.3L
All PMs will be answered this morning and my inbox will be clear again. Sorry for the delay.
zeekh
Upstate NY
I think thats a fine deal. Not as good as getting all the stuff but I'd like to stumble on that deal.
06GMC5.3L
Can anyone verify the following items in the Northeast are still at .03 level as of today/this week.
1000015009 Pfister Canton Faucet, 18.03
683275 Pfister Ashfield Faucet, 38.03
1001002481 Husky 33" Chest, 40.03
1001002482 Husky 34" Chest, 60.03
iSP
683275 Pfister Ashfield Faucet, 38.03 was not coming up yesterday... CT
06GMC5.3L
For those of you using the spreadsheet(s), I hope everything is going well and that using the Google Sheets app while in-store to search items in the Price Check App is helping you guys find deals. For any new findings I highly recommend taking notes on your phone (since I assume that is what most of you are using in-store), then updating the spreadsheet(s) itself when you have access to a computer. Updating it using the app can be very cumbersome.
chrisexv6
CT
This.
Not sure why the sheets app stinks on a phone but I've been taking pics in store then updating the sheet from a desktop pc
Sent from my LG-VS980 using Tapatalk
dragonballz
Massachusetts
Those 2 faucets did not come up in Nashua, NH
LT1CJ
Rochester, NY
Husky 33, 34 Chest just dropped to .06 level in western NY last week.
rpearlberg
Fairfield, CT
Besides the gas cap on the other side, is anything missing from this side of the CS-330T? I'm trying to look at pictures online to check...
Spn1025
New Hampshire
you should be able to download the .PDF manual online (Google it or get it off the HD website) which will show a complete parts diagram
GasEngineer
Northern VA
I found one of the Nutone ceiling exhaust fan for $40.03 in Northern VA. It was actually in the clearance section section with a $129.00 yellow tag on it.
Updated the spreadsheet accordingly.
06GMC5.3L
Thanks!
I haven't found any around here yet.
Status
