Split (open) adjustable round dies
seagull369
Was hoping someone could explain the point of these apparently adjustable dies for cutting threads. In the past I usually just avoided 'em in favor of the fixed hex-shaped dies, but today ran into a Horror Fright Ti set at a flea market at a price I couldn't pass up which is chock full of them. If for nothing else, I don't like 'em since they force you to use the 3 screw stock handle, which can't really be turned if you're working in a tight area.
justanengineer
Motor City
^^^This. Being able to adjust your dies and/or taps as they wear or when you need a special thread fit is very handy at times. I often open them up a tiny bit to chase threads as well. JMO, but I find non-adjustable dies to be one of the tell-tales of low quality. If its non-adjustable and the packaging/advertising doesn't tell the thread class then buyer beware.
Finky198
North East
Split dies tend to be more for thread repair at least that I have used them for in the past.
The adjustable dies like the Snappys are nice to. And perfect for... well adjust the tolerances of the fit
larry_g
oregon
Steinmetz
Washington State
We have different classes of threads. They are adjustable for that reason.
seagull369
that is part of what separates a machinist from a mechanic.
Guess that makes me a mechanic :D
Thanks for the info, guys. Didn't realize there was more to it.
kunkernator
US of A
I think to the general mechanic, non adjustable dies are fine. I have some nice ones (not cheap by any means), that are non adjustable. Then again, i use a die about every 10 times I use a tap....
