I ran a 1\2" gas line out to my new garage for my radiant heat setup and I am pretty sure I need a bigger gas line. Hopefully someone here can tell me for sure. Here are the specs:
Takagii T-H3M-DV-N THWH. 5.0w.c. min and 10.5 wc max
Run is 70-75' from the house. 1-1\4" gas line pretty much up to the exterior wall in the house and then 1\2" to the new garage
I ordered a manometer to test the pressure, but I am pretty sure I am screwed. For some reason I was thinking because the Takagi T-H3M-DV only had a 1\2" inlet and would only run at 30-40k BTU, a 1\2" gas line would be fine. I am worried it will not even turn on if it does not detect enough pressure
Any help would be appreciated.
