LoneGunman
A few members here were interested in finding a way to restore their impact sockets or Snap On industrial finish tools. I'm using black oxide for all of the nuts and bolts and some other parts where wear is a concern during the restoration of my Dayton bandsaw.
You can purchase the black oxide kit from Caswell, as I posted previously, do not get the kit just get the black oxide concentrate. Follow the instructions exactly, the biggest problem with the application of any plating or coating is lack of surface preparation, if the material is not degreased properly you will get a crappy coating, even the oil from your skin can ruin coatings.
Make sure you use distilled water for the black oxide mixture.
You do not need Caswells cleaner, it is overpriced. For small parts brake cleaner, acetone, MEK, will work fine. I use Simple Green in a large container that is heated to 180 degrees, Simple Green works, obviously not as good as solvents but I plate quite a bit and would be using way too much solvent. After the part is clean do not handle the part unless you are wearing gloves. The final rinse should be done with distilled water or water from a reverse osmosis system.
Tie a piece of fishing line to your part, lower it into the black oxide and rotate the part through the water for 1 minute, the parts take a maximum of 3 minutes, anymore and you'll get a sludge buildup on the bottom of your container. If this happens it can be strained using coffee filters.
After the part is removed it may not look a very deep black, it also may have some rust spots. It is extremely important to wash the parts with tap water then immediately submerge in oil. I use a water dispersing oil that I purchase 5 gallons at a time. Caswell's oil is also overpriced. Plain old motor oil will work, even used motor oil will work fine. Remove the parts from the oil after a few minutes soaking and rub down with a red shop towel or blow them off with compressed air (very messy).
The MAC socket I had lying around and looked worn, the other parts in the pics are parts of my bandsaw. The last pic is a pic of the oil draining back into the container, if you do a good amount of black oxide it's worth it.
THANKS, Lonegunman!!!!!!!!!
