Pipe Flaring Tools
Southern Europe
At the moment I have a regular pipe flaring tool, but would like something a little better. Whats the "norm" in tube flaring tools? Is it regular, double flare or bubble flare? Should I go with the SAE or metric or both?
45 or 37 degrees?
Are there any good manufactuers that you suggest? I'm leaning toward OTC
Thanks
ricleh
Sacramento, CA
Mastercool (MAS71475) Universal Hydraulic Flaring Tool Set
This will do all the flares you described. For 37 degree AN flares you can buy the MAS71098 adapter and die set to use with the universal flaring tool.
This will also do push connect flares and GM fuel line flares.
66HertzClone
Long Valley, NJ
I have this one, from Eastwood. I have used it many times on stainless lines which are very hard to flare properly. It worked flawlessly each time. Here is a link to it on their web site. http://www.eastwood.com/professional-brake-tubing-flaring-tool.html
35mastr
Norcal
This is also the one that I prefer. Makes perfect flares every time.
35mastr
Norcal
I'm looking for something in the $50 range, thanks
For that kind of money. you are not going to find any thing other than a regular one that just clamps the line with the adapters.
If you are doing any kind of brake work. This is not an area to cut any corners.
