Need painting advice
IRQVET
Forgotten Coast (FL)
I was spraying some cabinet doors with Benjamin Moore oil based paint. This was my first time spraying oil based and with incredibly thick, so I added some paint thinner and it only got thicker. (Head Scratcher) So I proceeded to use water which seemed to do the trick, until I checked on it this morning and now I have paint bubbles everywhere.
I purchased some mineral spirits after doing some research and determining that is what I should have used in the first place. But now I'm wondering if I should use the same paint gallon I added water to?
lessersivad
Morenci, MI
The paint you added the water to is now contaminated.
It should have been listed on the can as to what sort of agent (thinner) to use for clean up. As a general rule, THAT is what you use to thin the paint with.
I've used the "when in doubt, use lacquer thinner" to thin paint if it's an unknown from the label.
Don't know if that would work for latex though. Never tried it.
creativecars
Indiana- where horse and buggies still roam
It make a mess. A friend was helping clean some brushes and thought thinner would be better than water. Good thing they were the cheap brushes.
To the OP, you now have some paint you can use on the back sides, but I would not use it on the surface you will see all the time.
Zeke
That's impossible. You sure it was real paint thinner (usually mineral spirits, lacquer thinner or naphtha)? Water in oil based paint?:confused::dunno::Toilet:
I
IRQVET
It was just the paint thinner they sell at Home Depot, Kleen brand maybe? (I don't remember)
I was feeling better about the decision (momentarily) when my neighbor came by to look at it and said he did the same thing with the same results. My bubble was busted when I got to work and one of my co-workers said, "You've never heard that oil and water don't mix."
Here's your sign :headscrat
Cyberbear
California
In the future when in doubt as to whether or not a thinner and paint are compatible, I've always just filled the cap of the thinner container with the thinner, then added a single drop of paint. If it mixed well, I was good to go. If not, then I knew. Simple, rather than dumping an unknown thinner into a batch of paint.
CGT80
IE, SoCal, USA
Traditional oil based paint is generally thinned with mineral spirits which is what paint thinner is. There are hybrid/water modified alkyd paints that can be cleaned up or thinned with water instead of thinner. Pentrol is a product you can use to get the paint to flow better, if it is oil based and not water clean up. Oil is a whole other animal compared to water based products and the hybrid or water clean up oil based products **** in my professional opinion. I finally gave up on them and went to priming and using water based finish. White oil based paint is prone to yellowing if it doesn't get sun. Are you staying with a conventional/hvlp or airless? Compressed air can have a lot of water in it and will cause problems with solvent based finishes, but odds are very good that you used the wrong solvent.
countryroad82
Kentucky
Boy oh boy I wish I had a dollar for every time that moment of horror has entered my mind :lol_hitti . If it were me, I would trash the paint that's been watered down. If it were thickening up as you mixed it, it could have had a reaction to the thinner. I seem to recall something like that happening to me back in my early days of painting but I don't remember what caused it.
I
IRQVET
Primer- Zinniser oil base alkyd
Paint- Benjamin Moore oil based alkyd (off white)
Method- HVLP at 30 psi
I don't know if that helps. My background is commercial aircraft painting back in the late 90's (Enron). But I have to admit I'm not super knowledgable about other paints and applications (I'm kinda a one trick pony in that regard) and I haven't painted much since, just a few off road rigs here and there for friends.
Leeboy20
Kamloops B.C. canada
I would toss that paint and grab your new finish coat from a different paint store . Go with a " hybrid " style enamel like it was mentioned above. I've never had or heard anything good about B Moores hybrid or oil base . That being said, they have lots of great products . Hybrid gloss will finish like glass ( even with a roller) and be very durable . Your primer your using is top notch .
scottydosnntkno
Find a Pittsburgh paint or ppg paint store and get some breakthrough. It's an acrylic enamel hybrid design for cabinets and other high traffic areas. Being acrylic it dries to the touch is twenty minutes, levels great and is water thin which is great for hvlp , assuming yoU are laying the doors flat to paint and dry.
We paint 50-100 sets of cabinets with it every years. It's a great ultra durable quick drying product.
Git
S Cal
What are you using to spray with?
Latex paints are probably the hardest thing to spray. Your going to want a good quality acrylic latex paint - preferably an enamel
Acrylic resin is the 'binder'. Cheaper paints will use vinyl.
One of the most popular paints for spraying would be Sherwin Williams Pro Classic which you can usually get on sale for around 40% off
http://www.sherwin-williams.com/homeowners/products/catalog/proclassic_interior_acrylic_latex/
Another alternative if your looking for something in just white or black would be a 'colored poly' which actually sprays out a lot easier because it is much thinner.
Again not cheap - but you get what you pay for
https://generalfinishes.com/profess...nted-acryilic-high-solids-finish#.VjDxhLerRA8
CGT80
IE, SoCal, USA
I have been away from doing painting as a pro for about three years, but did it for 17 years before that, and products change all the time. My line of work was residential and commercial painting and cabinet finishing with a few personal auto paint projects thrown in. It was common for us to spray cabinets with oil, but about 10 years ago, I switched to doing mostly commercial work and didn't do cabinets very often. It got to where oil based paint was not worth using or wasn't available in a good product. Behr became my go to paint and their water based product worked as well or better than anything else I used and it was available all over SoCal and until 10pm at HD. I did many other trades and was at HD all the time anyway. Painters have their preferred brands and some may have been better, but our customers liked the lowest bid and were thrilled with my work. I used some $50 per gallon SW interior water based paint for a restaurant, 10 years ago, and saw no benefit. Needless to say, I wasn't in the habit of trying all the expensive products to find a high end finish.
I love zinsser cover stain, both in oil (that was all we had for quite a while) and in water based. It sticks to glossy surfaces and kilz claims to require sanding or deglossing first. 123 and BIN (shellac based and thinned with alcohol) were also very good.
Without looking at the paint label ( I didn't use much BM) it appears to be solvent based. If it says to clean with paint thinner, it is solvent based.
I have a really nice binks 2.5 gallon HVLP pot setup, but used mostly Binks conventional 2001 guns.
If the paint got thicker when you mixed it, that is the problem and it won't matter how you spray it. I always use home depot for thinner, unless I am using an auto paint, and the paint thinner I have had around the garage has worked fine for thinning oil based cover stain and rustoleum oil based paint. That can has been around for about a year as well. The new lacquer thinner I got at lowes last week, had a different label and the HD paint thinner seems to have had a few changes to the label in the last few years.
I do not know if the thinner formula has changed much, or if the labeling/wording has just changed to meet AQMD/EPA rules. Some of it says for cleaning, but not thinning. If you add it to paint/primer, the VOC's go up and the "authorities" have a problem with it.
I know a guy who owned a paint company in SoCal and dealt with all this and knew the chemical side and political/business side, but I have not seen him in person to ask him about it.
Like others said, abandon the batch that got thick. Try some straight paint, if you have any left, with a different thinner if need be. I have not had paint get thicker when adding thinner. Who knows what would happen with the wrong solvent though.
That breakthrough paint sounds cool. You need it thin enough to atomize and flow, but not run, and you want it to dry fast enough to keep stray particles out of it without it flashing or doing anything else bad from too fast of a dry time. With your past experience, it will probably be smooth sailing once you get a material that is working properly.
The hybrid oil that cleaned up with water (devoe and glidden had them) was thick and it dragged like you were trying to brush honey. It dried way too fast to get nice results from brushing and rolling. The worked looked OK but it was a paint to use. It stayed tacky for a long time and felt like duct tape adhesive and it had an odd scent to it.
I don't remember if you figured out what your paint needed for cleaning and thinning, but try mixing a small amount of straight paint with some water and try the thinners on hand, and see what happens.
Talk to the BM store about the paint. They should be able to help you out. I tried some of the devoe hybrid and didn't like it and ICI paints made it right for me, but I was a regular in there at the time.
I am assuming you mixed the paint well before trying to thin and you used a clean container, since you have experience. That thinner may be junk.
BM has water borne oil based alkyd paints that they claim have all the properties of oil but clean up with soap and water. Do you have a pic, full name, or model number for that product?
