CompressorPros.com
I get asked a lot about noise levels for the air compressors we sell. Sometimes we have a quick and easy answer, and sometimes we have go with approximates. Maybe some may find this helpful.
The problem is that manufacturers typically do not publish dBA levels on anything they are not trying to market as a quiet compressor.
A ball park answer for most two stage units will be a sound level in the mid 80's. Oversized cast iron pumps tend to be quieter because of the low RPM. This does not apply to cast iron pumps turning fast as is the trend especially at 7.5HP. Most compressors found in the consumer market (Harbor Freight, Lowes, Home Depot, Tractor Supply) are in this category. If you don't like crazy loud noise, don't even look at an oil less air compressor that is not an industrial machine.
To a lot of people, cost drives their compressor purchase decision, which is fine, but it's hard to find a "quiet" air compressor less than $1000.
Enclosed piston air compressors are available...BelAire, Chicago Pneumatic, Quincy and Champion (I think) make enclosed units that are a good bit quieter, but you pay a premium.
Rotary screw compressors are extremely quiet, but costs are high and they are not a good fit in places that don't need air all the time.
Some units that we have found to be decently quiet are the BelAire 5020P, 5026VP and 2061V for single stage. (This is compared to other brands that I have heard). The Chicago Pneumatic RCP-220P and RCP-226VP are the CP equivalent of those.
For two stage, the BelAire and CP Iron Series are good, with the RCP-C7581VSC2 being the best. It has a 10HP pump running at 7.5HP.
C-Aire's and EMAX's 7.5HP are similar to the big CP unit. Probably in the mid 70's for dBA
Here a few if you want to take a look...
http://www.compressorpros.com/quiet-compressors/
