BigE
I had to replace a set of heads a few years ago and I purchased a cheap torque angle gauge from a big box parts store (AA, AZ, etc. - can't remember). It didn't work well at all. It relied on friction to keep the gauge 'in place' when turning the bolt but, more often than not, it failed to do so. It made it very difficult to torque to the required angle confidently. I have another head replacement I have to do that will also require use of a torque angle gauge (unless I go with aftermarket non-TTY bolts). I will be doing it in the truck so I have to be able to clear brake booster/AC with it on a wrench/ratchet. That being said, does anyone have a recommendation of a specific torque angle gauge that you know works well? Snap-On, MAC, etc.?
Edit - Just to add information, the work I'm doing now requires the head bolts to be torqued in 3 steps. Step 1 is a torque value. Step 2 is an additional 90 degrees. Step 3 (final) is an additional 70 degrees.
