GETRIDAONE
Thanks for the reference, got excited as the 1 1/2 balls were only $2.14 each, but then they wanted $12.50 to ship them. Ouch!
Maybe you could find an "ornamental iron" supplier near you.
You're sorted then. Amazing how things turn up when needed and least expected. Just goes to show, we all get the odd bit of good luck occasionally.![]()
CRS: It might. One of our clever members did that nice artwork. I think it was MCBrownie but not positive. Good luck
BTW I haven't forgot your package and was actually pulling out some boxes today.
Glad to hear it's parted.I bet there was practically ****** all surface corrosion holding it too?
Bent, possibly. I'd be looking more at the key and way initially though, if there's still a problem after cleanup and lubricating. It's one hell of a task to bend a slide. Pop a straight edge on the slide. That'll tell you quickly enough whether it is bent or not.
Just kidding I have an American Scale that is a big hunk of rust and will be a challenge to get the slide out. It lived on a steel post outside and when it became inoperable was pulled up and put with a bunch of old tractor parts at the edge of his field. Right now it would make a good 180 lb. boat anchor but I'll fix it one day.Good to see you got it out!
My guess is that there is probably a little burr somewhere, probably in the keyway or on the key. Probably wouldn't hurt to run a little fine sandpaper over the edge of the key to make sure it's all smooth. I'd also probably wrap a dowel with scotchbright, chuck it in a drill, and use it like a hone in the inside of the body. Spray it down with wd40 good too. This should clean out any rust or little bits of **** in there. Wipe it out with a rag, rub the slide down with scotchbright, oil it up and try sliding it in. My bet is it will slide in like a new vise.
Sent from my C1904 using Tapatalk
A case of patience pays off. If it were me it would have come out a long time ago or be brokenJust kidding I have an American Scale that is a big hunk of rust and will be a challenge to get the slide out. It lived on a steel post outside and when it became inoperable was pulled up and put with a bunch of old tractor parts at the edge of his field. Right now it would make a good 180 lb. boat anchor but I'll fix it one day.
Shift: i'll post this Wilton bullet with the BLO on it and if you want more pictures of the cool welding table just ask and i'll email them to you. sadly the table didn't go home with me because a few years ago i didn't have the tools to move it. maybe my favorite vise is this Reed 4C that you might have seen me post a time or two with 3 coats of BLO.
good luck
So many notables:Shift: i'll post this Wilton bullet with the BLO on it and if you want more pictures of the cool welding table just ask and i'll email them to you. sadly the table didn't go home with me because a few years ago i didn't have the tools to move it. maybe my favorite vise is this Reed 4C that you might have seen me post a time or two with 3 coats of BLO.
good luck
Also, I see a stand of some sort in one of the photos with a wheel/rim at the base. I'm looking to find/make one myself. Looking for ideas.So many notables:
That Reed 4C.
That puppy's 1000-yard stare.
That table though.... Les Desírables.
I respectfully request more photographs of the table, please. Email to my username @ gmail.com. Thank you in advance.
Sent from my SM-N910V using Tapatalk
Thanks, Drives!
. And no red paint on the main body.No clue on the Franken Vise answer but I'd guess there si either damage you are not seeing or that as you suspect two bad vises were used to make one bad vise...
First some measurements:
is the slide on the Dynamic concentric throughout it's length? (mic it or use calipers)
is it straight (use a straight edge on 4 sides
Is there hidden damage in the static base bore? galling? other issues? (Inspect and get some light in there...) is that bore straight? (hard to do, but again with the straight edge)
if it has galling (look at that 3" mark...) that needs to be addressed
