Do pairs of combination wrenches with different sizes on each end exist?
Tooling Around
I was recently thinking about whether manufacturers should make combination wrenches in 'pairs' with different sizes at either end. I've labelled the picture below to show how they would be labelled (the Joker wrenches aren't actually made with different sizes at each end!).
The idea is that you could use the 'open' end of one wrench to hold the bolt head and the 'ring' end to turn the nut. Does anything like this already exist?
davethorik
Norka, Ohio
The small sets of Craftsman ignition combo wrenches are like that, can't say I've seen it on bigger combos. Double box end wrenches are like that, though.
Ruahrc
I don't know about combination wrenches but I believe this is common for double box end or double open end wrenches. For example I have some double open end wrenches that step up in size:
1/4 and 5/16
5/16 and 3/8
3/8 and 7/16
Etc.
sam.coll
Melbourne, Australia
1/4 and 5/16
5/16 and 3/8
3/8 and 7/16
Etc.
Of course its common for double box and double open end, what use would a double box/double open end wrench with the same size on each end be?
toolmutt
Texas
That's the concept of owning double box end and double open end sets. Take, for example, a set of combination wrenches, 10-19mm. That requires ten wrenches but you only have one wrench per size. A set of dbe 10 through 19 would be five wrenches and the same for doe. Still ten total wrenches but two wrenches per size; one to turn, one to back up.
dutchgray
Dorset. England.
You can get DBE which have a standard box one end and a ratchet the other, they are handy as you don't abuse the ratchet breaking fasteners.
I think I have seen some with 6 & 12 point on each end as well.
Having different sizes on a combo wrench would just get annoying.
sam.coll
Yes a different function, same size on each end of the wrench obviously makes sense
Can I try?
SE PA
I wanted something similar recently. I came up empty on my search, so I made it myself.
I service a piece of equipment at work that has a few frequent adjustment points. One requires a 7/16" open end, another requires a 9/16" box end. I took a combo wrench in each size and chopped them in half near the open end. I then welded the 7/16" open end to the 9/16" wrench where its open end had been. Now, when I get a service call for that piece of equipment I only need one wrench, where as I used to need two.
Karl_B
Killeen, TX
I have a few old Indestro and other brands of wrenches like that. The one I remember best has a 7/8" open end and 3/4" box end. Personally, I try to use a hinge handle and socket on one end if I have a nut and bolt with the same size heads. A socket keeps that end captured better.
Askme42
Goreville IL
Was it that bid of a deal to carry 2 whole wrenches?
bob15
Northeasten, CT
Yes they do exist.
Billings and Spencer. 11/16 x 3/4
McFarmer
I have a Barcalo wrench that way. Three quarters and seven eights if I remember correctly.
MikeF2316
Thornhill, ON
I have come to the conclusion is that this is how it should be. However, it was much too late for me, I have 3 sets of traditional combos. I also have one set each of DOE and DBE. I try to grab the DOEs most of the time but old habits die hard.
larry_g
oregon
Bierisch
San Antonio, Tx
I've got two wrenches like that!
EDIT: Don't know what happened with that redness, sorry...
sam.coll
erikohio
ohio
I know this is an old thread, but when you have the photo of bigfoot, you bring it out when needed. Aside from the craftsman smalls, I have this guy. Duro/indestro to the rescue. 9/16 box by 5/8 open. I'd personally date this around late 30s it is indestro, and also select steel. I've always been more curious about the poly sided hole punched. It's to centralized for hanging the tool. It hangs at about a 40 deg angle from it. And why 5 sided, or shaped at all instead of just round? The mystery may never be solved, but it's more proof duro has always been way ahead of its time!
dscheidt
I had a few wrenches of this style, newer than that. I don't remember what the maker was, but I'm prety sure they came with a machine of some sort, and were to save a couple wrenches in the tool kit. They were pretty crappy wrenches, which is why I dont' have them any more.
