3/4 Breaker Bar
2mJps
north central Mo
What is a good cheaper one? I need one to have with me in my truck to change flats and i dont want wear the chrome off a high end one rideing around in the trucks tool box and i dont want one that is going to break when i need it most.
honcho
Near Sodom & Gommorah (aka Wash. DC)
I vote Harbor Freight
With enough force, anything can be broken but I've abused a Harbor Freight 3/4" breaker bar with plenty of cheater pipe with no problems to the bar. I've had 1/2" drive sockets break using them on the 3/4" bar with an adapter since I only have a couple of 3/4" drive sockets but that's another story.
cliftonbros89
Missouri
I just ordered the new SK one. I think it should be pretty good. Also have an older Snap On one I got via Craigslist.
Finky198
North East
+1 on the HF it's worked for many years
I also have a craftsman usa which is not to bad
Kobalt one seems nice for the price as well
I can't see spending a ton as it's hard to mess up a tool like this
martin666
New Jersey
Another vote for Craigslist or ebay, Armstrong, Proto, Wright, Williams etc. can all be found at great prices, all it takes is a little patience
JBradley500
I got a used/like new Proto for less than 40 shipped (maybe $35?) on eBay and I am glad I got it over what I was seeing at HF. It's quite a beast in comparison.
PJNJ
Iowa
I have a used Proto I got on Ebay a few years ago for $25.00. I'd take it over the HF any day. And I have the HF 1/2 which is actually pretty good.
:beer:
I found my buddy a 3/4" drive set on CL a couple years ago. (I myself don't work on stuff that big.) Grandson was cleaning out late Grandfather's garage and shop. Got it for about 40 bucks, as I recall. Breaker bar, sliding T-bar, extension, and a mess of sockets, all in a hand-made wooden tray - WWII vintage. A lot of it was Wright. Rest was all oddball mis-matched.
So I asked buddy a couple weeks ago "You ever use any of that 3/4" stuff I gave you?"
He says "Yeah, I was working on a piece of tracked equipment. Had to run home to get
the big socket set. Told the guy "find me a piece of pipe"."
He continued "So I got back about an hour later, and the guy dug out a 10-foot piece of pipe for me. Put it on the breaker bar, stood on the hood of my car and jumped on the end of it. After about 3 or 4 jumps, that nut finally broke loose."
So.... yeah: as said above: find an oldie on CL cheap. One that "Grandpa" already put to the test, and you'll be fine.
619DioFan
San Diego , Ca.
3/4 inch drive titan tools breaker bar ( 40'' long ) very good tool. I also have the 1 inch drive version ( also 40'' long ) this one is a beast. think it is rated for 2000 lbs of force.
shamrock12
South Dakota
Here's a crazy idea ... how about making your own tire iron? If you're looking for something just to keep in your truck for changing its own tire, then maybe just buy a short stick of 1" 1020CD round bar or so (assuming it's for a pickup) and a cheap impact socket. Weld them up and volia, you got yourself a custom, cheap tire iron.
Zrexxer
Pflugerville, TX
Are we talking a pickup truck or a heavy truck? Because if it's a pickup, there's no need for a 3/4. Just get a 24" 1/2" dr and you'll have all the leverage you need. My Silverado requires a 140 ft-lb torque on the lugs, and I carry a Matco 24" breaker in the toolbox with a 22mm deep socket.
zkling
:+1: My trunk HF breaker bar and halligan have although been the topic of many jokes, have both saved the day many a times.
Moose2367
What do you people work on?
Tractor trailers with rust?
M1A1 drivetrains?
D4 dozer, 120G Grader, any one of 6 old tractors and a brand new 170hp John Deere, Timberjack Skidder, Bobcat, flatbed cattle truck.
This is all gear we have on the farm.
2jz4me
se indiana
I absolutely recommend the snap on breaker bar. Toughest bar i have ever used and shockingly not too bad price wise.
L872RM
L8112A
The toughest job i used them on were seized on bobcat lugs. I was in shock how easy it made it after the hard time i had with them.
Wakefield
Arlington VA (but would like to get out to country
Five or so years ago-weren't the Snap On modular 3/4" drive bar tools upsized in diameter? (two or three bars of different length,a ratchet head and a "breaker bar" or hinge handle head and a slider piece) that are put together to make the desired tool
(ones from different years might not fit together)
RedneckWelder
The Ghetto Kingdom of Methlandia
M1A1 drivetrains?
Stuff that makes an M1 look small.
2mJps
north central Mo
Its a 1963 F600. I broke my wright 3/4 breaker takeing off the front tire. I have a wheel wrench that is right size that looks like something that may have come with it but it looks inadequate.In need to try it and see how it holds up.
Mohawk Dave
SoCal
Same here. I'm surprised this is the main recommendation. The F&F are beautiful as well. :beer:
Mohawk Dave
SoCal
Yes, from 13/16 to 15/16.....fiasco trying to warranty one piece and explaining to the nice Snappy ******* the phone why it's all or nothing.
But the PNs did change so you just have to see what the new parts are and then you can deduce....
Farmall 1066
Suburban Rockford, NE
Unless you need it right now, I'd cruise pawnshops and auctions for a good old name brand one. Heard several people say HF, but I bent one all to hell just standing on it this spring.
I'm 6'7" / 325#, so YMMV.
In fairness, I may have jumped on it a bit...
