Generators- Big Boys
Nicnumber1
Alright folks,
Been lurking for sometime and wanting to contribute to the forums. Can someone school me on the generator game? Preferably ones that can be moved and can power a welder and air compressor. Would also be nice to have a good one that I can use for the house once I stop moving for work.
Thanks in advance!
Edit- things I should have included:
Would like to stay under $3.5K
Already have nice welding and fab equipment
Prefer something not integrated
BD1
north side
Miller Trailbllazer airpak. Done.
Cool ! That will put a BIG DENT in his pocket.
You may need to down size to a bare TRAILBLAZER. The positive side is it will power your house , air compressor , and give you a welder too .There's one in my avatar.:beer:
Bobcat753
New Hampshire
Yes get a trailblazer:evil:.
In all seriousness running a welder off a generator isn't very nice. Most generators besides the welder generators are choppy with their power output. I'd look into a Miller Bobcat or Lincoln Ranger. Should be within your budget and they both have fairly smoother power than a regular generator. Plus you get the benefit of having another welder:lol:
txvwnut
Bedford, Texas
Talking from experience you'll want a welder/generator package. Depending on the size of the welder you want to run will depend on the size of the generator you get. I've run a 110 wire feed off of a 6500 watt generator and it was actually too small for it. I could only weld in short bits as the welder shut down on low power or the generator breaker would trip. A compressor will be greedy on startup so you will need to take that into consideration too.
theoldwizard1
SE MI
Get a 240V welder. Twice the power.
I run a 2HP oil lubed compressor off of s 6500/5000 watt generator no problem. I'm sure it would run a 3HP. In theory, it should handle a 5HP compressor.
Of course we are talking about running the welder and compressor separately.
N
Nicnumber1
Miller 210
3.5 HP Compressor
Plasma
Miller diversion Tig
Bendpak for Bender
Assuming I need atlesst 12kw
Wondering if there were other options besides Lincoln and Miller
dr_clyde
Holland, MI
Why does this need to be done on a generator? Realistically, a good generator that can run those tools is going to be at least 5k no matter the brand.
honcho
Near Sodom & Gommorah (aka Wash. DC)
For most bang for the buck, a military surplus diesel generator 10kw to 30kw on a trailer. It will be mobile, capable of meeting the OP's requirements and generally they are readily available within his budget. Single and three phase power are available. Just don't buy a 400hz generator!
theoldwizard1
SE MI
Miller 210
3.5 HP Compressor
Plasma
Bendpak for Bender
Assuming I need at lesst 12kw
Depends. What is the power requirements on the plasma cutter and the compressor ?
Everything else would run comfortably on about 7-8kw (assuming one at a time). the plasma cutter requires running the compressor at the same time. 10-12Kw is just a SWAG until we know the actual input of those items.
Generac, Briggs and Stratton and Honda all sell 10kw generators. Generac and B&S MSRP are within your budget.
east_tn_emc
East Tennessee
This! My 10kw -003 doesn't even notice when my compressor kicks on.
