deucenut
Well it's finally time to build my mezzanine. When our house was built, I managed to convince my wife to let me get the garage built extra deep. :thumb up: So I ended up with a 19'6"wide x 29' deep garage with a 13.5' high ceiling. So I am going to build a mezzanine next to the stairs from inside the house.
PLAN:
My plan is to have a 16' wide x 10' deep mezzanine. I plan to use (3) 2x12's glued and nailed together as my front beam(span is 16'). I will use 2x10's for the joists which will be 12"o.c. and have joist hangers at each end.(I am not cantelevering the joists as I want to maximize head room, both above and below the mezzanine). The joists will have two rows of 2x10 blocking with the rows spaced evenly in the 10'. I am planning to use a 6x6 post at either end of the beam that sits on the concrete floor. The ledger will be a doubled up glued and nailed 2x12s. The flooring will be 1/2" or 5/8" plywood. All 2x's will be spruce with the 6x6 posts being fir.
QUESTION:
Will using a tripled 2x12 be strong enough to span 16'? I plan to use the area as storage and work space so a lot of weight will be up there.
I don't want to put a post in the middle of the beam span because I want to put a car sideways under the mezzanine. Thanks in advance for the help
PLAN:
QUESTION:
