scootermcrad
Hey everyone!
I'm working on some layout work for a large addition to our existing garage and have some questions regarding the concrete work. I'm putting some basic plans together for the structure so I can clearly convey the addition plans when I have contractors come to quote the work. I want to make sure I'm educated on what would be best for my addition before people start coming out.
The current garage is an older 2-car garage (approximately 24 wide by 21 deep overall). The slab has a slight slope to it, towards the garage doors and appears to be what local code would require. We are adding to the front AND back of the garage (this works out for our lot layout). 16 feet to the back of the garage with a single bay side entrance and 12 feet to the front of the garage and moving the doors.
The questions really come when I start thinking about the slope of the floor on the rear 16 foot deep addition. This area will have the side entrance for a single car and then the rest of the space will be used for my machining tools. Is this portion of the addition best to be flat with a center floor drain, slope with the existing slab, or should the direction now change to slope out the side door? Additional thing to note, the rear 16 foot addition will be a heated slab, with PEX tubing set in during the pour. Does this change the answer?
I'm assuming the front 12 foot addition can just continue with the slope, same as the current slab. Would that be correct?
It probably doesn't matter, but the construction of the rest is full brick veneer over stick framing.
Anything you concrete experts can share, would be appreciated.
Thanks!
Thanks!
