A stove pipe question
LOTW
Northern Minnesota
I just acquired a new wood burner. My chimney goes strait up through the ceiling and roof.
Here is my question, how can I install the pipe from stove to ceiling without removing (lifting) chimney? Do I need to add elbows to give me some wiggle room to assemble the pipe?
Ironhorse74
MEMBER EMERITUS
The Pacific North Wet
http://www.woodlanddirect.com/Single-Wall-Slip-Connector?gclid=CLeFm6fXickCFQqEfgodgWwN5A?gdftrk=gdfV23673_a_7c1677_a_7c8224_a_7c2590074_a2s__a3a__a2s_2590075#259Diameter:6"
You use a slip connector at the top. Male ends point down and three screws per joint. Something like this.
Brad
tkelly
Bricks I like the brick idea, used it before, not bad for a mechanical engineer.
L
LOTW
Northern Minnesota
Thanks guys. Me, you aren't the first person to suggest setting it up on blocks, I do appreciate the advice!
The telescoping pipe would be perfect but the local hardware store didn't have one nor did their supplier. They had a draw collar in galvanized but were unable to get one in black.
I could order what I need but I thought about it clfor a second before going to the shop and building a draw collar.
Took me 20 minutes to roll up a piece of sheet metal I already had. I'll finish it up tonight.
L
LOTW
Northern Minnesota
Someone said instead of bricks just leave my floor Jack under there to make it easy to clean the pipe.
Nice, he was an engineer too.
L
LOTW
Northern Minnesota
It worked out ok, lighter ga would have been better, it would have tightened up nicer. As usual though I got by with what I had on hand.
Stove works great, drafts like a champ. Vast improvement over the old one.
