Picked up this Parker at a local transfer station and then ran like a banshi!
Joe, how does the lockdown for the swivel ?
When I went to pick it up today, I had in my head it was much larger, maybe twice the size, and was quite surprised how tiny it actually was. I couldn't turn it down though.
It's just over 2-1/2 lbs. and has a quick release operated by lifting the dynamic slightly and sliding it to the desired position.
As mentioned earlier not sure what these are worth, but paid approx. $9.75 per lb..... Slightly over the recommended going rate. Ha!
VA, this is in your neck of the woods.
I bought a yost 4" drill press vice today.
30.00 after using shop your way points, and I get 20.00 back in shop your way points.
The bad news is, I don't own a drill press. Ive got my eye out on craigslist for an old craftsman.
--------------------------------------------------------------------------So?????![]()
So I was taking apart my parker 433-1/2a for parts and wanted to share how it was built. It must have been built by union.
It has a pressed on stud with c-clip instead of a center bolt for the swivel base.
The main nut is held in by a wedge type piece instead of a pin.
The jaw towers are cut straight vs angled.
also the swivel base uses a smaller diameter swivel nut and bolt than the 433-1/2.
So, it don't swivel.![]()
)So I was taking apart my parker 433-1/2a for parts and wanted to share how it was built. It must have been built by union.
--------------------------------------------------------------------------------------Swivlin' is vastly overrated...
Now spinnin'...
There's something worthwhile...
(And as big as the b@#tard is, the workbench it's bolted to, would probably swivel/spin/rotate/screw/etc...)
So the vise doesn't have to...
You know I could bolt 3 heavy-duty casters to the thing.---Might go get it yet.---Thanks for the idea Old.![]()
BAGGED
I have a 973A in route to me and I see from the pictures of it, the swivel base is held with a stud and clip just like yours...
Well, it is most of a Bullet. 3.5" with the pipe jaws. Actually, i think everything is there except the pipe jaw retaining pins. Best part is it was free. Gonna get started tonight on it.
Even in that condition, you ****! Grats on the find ...
Brian
dkrothHemi,
Please post up some pics when you clean this one up. I saw it at auction on Saturday and I thought it was in decent nick. One thing I found odd - I removed the dynamic jaw and the nut was flopping around inside the body. It clamps well and the action is smooth so no problems. Just curious what's going on inside there.
[B][/B]
dkroth
The previous owner didn't know how to take a bullet apart.....He haggled up one hole in the nose piece and one in the nut.....He also had it packed with army tank track grease left over from Hitler's Panzer division....I have everything in the tank right now getting the **** off it.....I'll get some pictures once it is photographable......
One thing I hate is thick old grease. That's my least favorite part of resorting old tools. What do you guys use to get all that old grease off easily?
Paraffin/kerosene.
Parraffin or kerosene, or kerosene and paraffin mixed together?
What we call paraffin is what you call kerosene.What we call kerosene is heating oil. Anyhows, I'm digressing; Any of those will work.
A true viseaholic, yesterday you had spent all your vise budget and today your thinking about buying more.![]()
Yes, please.
The vise came from a farm so the only thing the owner cared about is does it work?
I just cleaned up a 1755 where the inside of the slice was solid grease. It even continued up into the hollow parts of the jaws! I scooped as much out as I could with a paint stick filling the better part of a soup can. Diesel to clean up the remaining residue before bead blasting.
608 Columbian and a Rock 577.---Make wonderful Christmas presents fellows.
http://www.ebay.com/itm/Vintage-Col...314077?hash=item3d0778105d:g:JHEAAOSwo6lWMrYA
http://www.ebay.com/itm/Vintage-Roc...922120?hash=item21053ecb48:g:1WcAAOSwAYtWPaQm
Pictures eventually.....
Well, unfortunately the 608 (actually 508 without the base) I was after had gone after someone waved $200 under the buyer's nose. However, at the next stop an hour down the road a complete Parker 436 was shoved in the trunk for $100 so goood enough.Pictures eventually.....
Thrumcap
