Total newbie here, just signed up the other day, so hello everybody
Anyway...
I am putting a Reznor UDAS-45 heater in my 2 car garage.
Electric and natural gas connections are ready and I got Reznor's connection kit including the concentric box.
Next step is to determine the vent connections for vertical venting through the roof.
The manuals provided by Reznor are pretty good in describing the venting post the concentric box.
Where I am struggling is with the connection between the heater and the concentric box.
I was planning to use 2 tees, directly attached to the outlet and inlet at the heater and then go straight up into the concentric box.
Now, looking at the location of inlet and outlet on the back of the unit, I am pretty sure they would actually interfere with each other, i.e. I wouldn't be able to place them so they are both in parallel allowing me to go straight up.
Here's a (crapy) picture with one of the tees attached:
Since I assume Reznor doesn't have some flawed design, what is the ideal way of connecting the heater to the box, e.g. first straight out, then a tee, elbow etc.?
I will be fairly flexible with both, the placement of the heater as well as where the vent will be going through the roof, so I should be able to accommodate whatever seems to work best.
Also, do I need dual wall pipes for the connections between the heater and the concentric box or can I use single wall?
Some pictures of how some of you might have connected separate combustion heaters would be a big help as well.
Thanks in advance!
GS
Anyway...
Thanks in advance!
GS
