catalytic
EDIT: New Concrete *Driveway* Heaves, causing Garage Flooding
Guys, I need your thoughts/opinions/recommendations. In Oct. 2013, we had our blacktop driveway redone with concrete.
- It was put in without the drain grate seen in the photo, but in the winter, the slab right in front of the garage heaved up and caused water to drain into the two garages.
- For the last 2 winters, the slab right in front of the garage heaved up 1.25", cracking this slab at the grate and causing the swale to effectively heave out. Also, the drain grate and drain tile froze, preventing drainage. This caused water to drain into both garages and flooded them so that they have standing water in the winter. It also means that we could not open the hinged doors in the left garage for most of the winter, because they hit the driveway slab.
- To contractor recently returned with an engineer and said that they could not have foreseen the heaving problem, and that they need to rip up the slab closest to the garage to dig and pour a footer that will reach below the frost line. The contractor is quoting ~6k, which is more than the entire driveway cost.
- Before proceeding with the costly footer plan, I wanted to get your guys opinion.
Details:
The whole driveway slopes gently down towards the garage (and towards the swale & drain grate).
The left garage's slab has lip that is 0.6" higher than the driveway in the summer. The right garage's slab has a lip that is flush with the driveway slab in the summer.
Both garage slabs slope towards the garage door & driveway, but water cannot escape in winter because the driveway heaves up higher than the garage slabs.
The high side of the property is the yard to the right of the driveway in photo 1 (where the car is parked in the picture). Along this right side is a 12" deep drain tile of gravel over perforated 4" pipe, which is supposed to take water from the yard to back behind/right of the garage instead of allowing it to drain into the driveway.
Details:
