mopar440_6
Need Help Finalizing Lighting Plan - Now With Layout
Well, the electrician pulled power to the shop today and the builder is coming tomorrow to hang the ceiling so its about time I make a decision on my lighting plan. But even after hours of reading through Platonic Solid's threads in here, I can't figure out what my best option is.
Building specs/lighting requirements:
-50'x60' pole building
-14'3" ceiling
-Walls and ceiling will be white steel panels, floor will be gray Rust Bullet
-Looking for 85-90 lumens/sq.ft.
-Would prefer lights to be run on 220v
-Need to be ceiling mounted (not suspended) strip lights
-Not opposed to buying fixtures and ballasts separately if it provides me with a quality solution at a reasonable price point
-Budget for fixtures, bulbs, and ballasts is approx $3000
My original plan was to use 5 rows of 6 of these:
Lithonia 8' TUNS-2-32-MVOLT-1-4-GEBHL
with these bulbs:
Philips-32-Watt T8 Daylight
But the Visual Interior Tool says I only need 25 fixtures. So, that would put that option at just under 2/3rds of my budget. However, I know those fixtures have a commercial ballast and with an all steel liner, I fear my radio and cell reception will suffer greatly. Also, changing bulbs on a 14' ceiling will not be fun so I started looking at some other options.
After reading the "Best Light Fixture Ever" and "Lighting Layouts" threads I started looking at the James Industry LED bulbs. I'm now kicking myself for not getting the 22w bulbs when they were cheap. If I could get them for the original $12.99ea price, I could still buy 50 of the Maxlite fixtures and come in very close to the same overall price as the fluorescent option but I think that ship has sailed at this point. The 18w bulbs are still available reasonably but the output difference is significant enough that I would have to increase the amount of fixtures to the point that they would become cost prohibitive.
Is there any benefit to using 4' tandem bulb fixtures vs 8' quad bulb fixtures?
Are there any other T8 LED options with a similar price point and performance to the James Industry lamps?
Am I completely off base and should be going in a completely different direction?
At this point I'm just pretty much overwhelmed by all the possible combinations so any direction or advice would be greatly appreciated.
-14'3" ceiling
with these bulbs:
It may be cheaper to run a lower ballast factor unit and just buy a couple more. The GC finished the ceiling today and the access hatch is dead center of the ceiling so I might actually be better off running 6 rows instead of 5 anyway.
