source for a 3/8" drive 1-1/8" deep 6pt impact socket
sherrod624
Sims, NC
I've searched everywhere and the biggest i can find is a 1". Anyone know of a brand, source, whatever for one?
lightning02
might want to make sure your 3/8s impact has the TQ to loosen/tighten a bolt that big with a socket that big on it before you buy.
dutchgray
Dorset. England.
I checked the Koken catalogue and they don't list one, makes me think it may not exist.
Use an adapter, the Grey Pneumatic ones are good, they add little length and have magnets to hold themselves on.
sherrod624
Sims, NC
I use 3/8 18volt brushless Milwaukee religiously for factory maint type work. I've tried it with an adapter and I don't like the slop that you get with an adapter. I feel the slop is hell on the anvil. I wouldn't be using it for high torque. I need it mainly for running take-up bearings up on conveyors and running motor bases in and out.
bobcatdan
Kaukauna,WI
Unless it is a speciality socket for an exact application, I doubt one exist. 1" is generally the max for 3/8" drive. I'd look at a better adaptors if you are unhappy with the one you have. They make a low profile adaptor to go from 3/8" drive to 1/2". The 3/8 female opening is in the 1/2" male so you have little more then a thumb wheel thickness between drive tool and socket.
lightning02
is it possible to make one? like tig weld the adapter to the socket so there is no slop? just an idea.
bigjeff94
USA
I also work industrial maintenance and my 3/8 Dewalt impact gets used a whole lot. But I haven't come across an 1 1/8 3/8 socket so the 1/2 gets used on them which kind of ducks because 1 1/8 is fairly common
theoldwizard1
SE MI
If there is too much slop with the adapter, but some shim material. You can get cheap thin SS on eBay and cut it to size.
JBradley500
Wasn't there a thread on something very similar to this a month or two ago? Maybe an answer is in there.
defektes
Arizona
Get an adapter with a pin anvil. 1 1/8 is very common size in industrial, would be very versatile to have a 3/8s.
However, I also work ind. maint and I almost never carry my 3/8s around anymore. I use my Dewalt impact with a 1/2 anvil but I have the QD impact driver.
