"ShopDog" a better Sawhorse build
Koy E
California, Bay Area
A long time ago before I owned a home I picked up a set of two plastic sawhorse's from sears. You know cheapo black plastic one's that go on sale in a two pack for something like 15 bucks. Well those came in handy on occasion. I now own a home which means I find myself doing more and more home improvement stuff so I decided to replace my flimsy saw horses with something sturdier. I shopped around Hd, Lowe's and online but most were expensive or not collapsible so it was an easy decision to make my own. I browsed the interwebs for a bit until I came along this website with a walk though on how to build "Shop Dog" sawhorse's Artofmanliness.There I found a step by step tutorial on how to build these neat Sawhorse's. Apparently this guy came out with the design.
Here's some pics of my build. I've only made one so far but plan on making another next week.
Got the 2x4 lumber,bolts,washers and nuts at H.D. The larger bench top wood is for a work bench i'll be building later using my 2x4 workbench kit.
Cut the legs to size.
Layed out he four legs to make sure I got the position and angles right.
Once the legs were done I proceeded to cut the lower and upper support peices. they aren't cut in this pic.
Next came the tricky part of cutting inner side of the legs at slight angles.
It was kinda frustrating not getting a clean cut or angle just right. It took some eye balling but the second leg set came out better than the first so I'm confidant the second sawhorse will be better.
Moving onto the assembly.Btw I used wood screws that didn't need pre-drilling to make the build a bit more convenient.
The result
I decided to use some scrap wood to build the ad-on miter saw bracket while I was at it.
I screw mounted the 2x4's from the bottom up and used some wood glue to give it a better bond. the Ketter work table came in really hand through out build.
And there we go so far.
BMW Rider
Calgary, Alberta, Canada
I built a set of them too a couple months ago. I had some nice saw horses all ready, but they are not foldable and took up a lot of space to store. This design seemed pretty good, so I went ahead and got the plans and built them. I added a couple of stretchers to span across between them to support a full sheet of plywood for initial cutting with my skill saw and guide rail.
cwh
Anchorage, AK
Thanks for pointing this out to me... they look extremely handy, and will be out of the way when not in use.
$5 is a bargain.
BD1
north side
AWESOME ! I see you have a Keter table too. I bought two of those and well worth the $50.00. Nice design on the saw horses.
K
Koy E
I've used my keter on several occasions and it comes in really handy. If you happen to frequent costco that's where it got it. At the time they had it for 50 bucks minus 10 dollars instant savings making it a good buy at 40 dollars. I've seen it go on sale at least twice within the last year or so.
Thanks for the compliments guys! If time permits i'll be making a video of he build for my second set since I think I have the technique somewhat down. I'll post up the results either way.
Stone Cutter
Wow!!!! that is a great sawhorse, great job too, you are to be commended.:thumbup: What's so amazing with me is, I bought the plans for the "Shopdog Sawhorses" and I still can't get those angles right. Even though the angles are not flush I can still get the "Jaws" to clamp down on the 2X4, but then afterwards when everything is assembled I have one of the legs a bit to short, by about 1/2"inch.:dunno: Your clamping of the 2 legs together for that pivot hole and using those straps is a great idea. Right now, I only have one completed ( not perfect ) sawhorse that I mount my mitre saw on. That was the 1st one I made last year. As for the other two that I tried to make, there going be used as firewood in my Chiminea this winter. But I'm determined to get it right, trust me.:thumbup:
Joe
carbon
I built one of those with the exact same plans. Excellent design for a miter stand.
theoldwizard1
SE MI
I missed this the first time around. I really like the basic design. As a real "wood butcher" I would have a hell of a time cutting those angle. I guess the trick would be come close to the layout line and then use a chisel or sander to "sneak up" to the line.
383 240z
Findley Twp. Allegheny Co.
Never heard of or have laid eyes on that design. Overall I kind of like it, but I would make 1 addition. Add a section of 2x4 or 2x6 to the top of the horse. Screw it on in the flat position, making a T. That way you can let your saw cut into it, it's sacrificial and easily replaced, also it will give you a wider surface to work on, handy for when your ripping boards, just run a pair of screws in, mark your line and cut with your circular saw. That way you have 2 hands on the saw, and not holding lumber near the blade.
carbon
The top board is already "sacrificial". In the last fellow's pic, he didn't use the recommended 2x6 which raises the board you want to cut up high enough so one doesn't cut into the horse. Look at the design and you'll see the top board is removable so the horse can be stored.
As I mentioned above I built this guy's design and it rocks. $5 well spent in plans. Ruined some boards trying to get those angles! Used one for a looooong miter saw station for looooong trim. Made a removable attachment for the saw, used a 16' 2x6" for the top board and added some simple sliding supports for the long trim. It stood outside for 4 months and it is awesome.
E12-535iTurbo
The Netherlands
The cross-beam can be taken out and is sacrificial. It's 2 inch wide so quite a wide surface already. It's also just a bit higher than the saw horse so you can cut into it without hitting anything you should not damage. I'm ripping sheets with a track saw. I clamp the tracks on to the sheet so both hands are free and if necessary can clamp the sheet on to the saw horse but that is dependant of the sheet weight.
These are replacing the flimsy cheep steel horses I was using before. Quite happy with them. It's not my design. I only posted for others to read.
(edit: Carbon, I do have the cross beams stand out a bit. Look at the left horse between the sheet and the upright.:))
bullnerd
Jersey
There's another style of cheap folding horse that uses a hinged board underneath to keep the legs separated, this would probably work here too to eliminate the strap and make it more one piece.
carbon
You can do it with a hand saw and hand drill no problem. In fact it might be easier to understand/set up the cuts.
carbon
That design is nice for a replacement for those plastic quick-fold horses. I've seen them use a chain instead of a hinged board as well. The wood version is undoubtably stronger than the plastic.
The shop dog is more of a replacement for very heavy duty stands or the very $ miter saw stands with long extensions to hold stock (dewalt DWX723). The top board can be swapped out for any length or style you like.
