Cheers chaps.
I'll post that recipe in a bit Shiftless.
I honestly hadn't expected there to be much, if any, interest in this finish, hence why I haven't done so already. It's just a blend I've been meaning to make for a few years now, but only just got around to experimenting with. In all honesty, the thing I initially intended for it had nowt to do with vices.
The main reason is for coating changewheels for the lathes, as I gradually clean up all of those. With them all being Drummond gears, hence having the same quirky tooth setup, I envisaged making & using this paste so that they would have a protective coating without painting them, so they could be swapped between machines without paint colour making them look misplaced, and it would also act as a dry lubricant for them to boot.
Aye Kevin, it is a very good quality casting. It probably is one of the closest to flawless that I've seen from a casting. On about you saying it looks like there's no finish there, I set myself off chuckling over just that same point after I'd done it, (yup, one of those old fart moments
). Just had a vision of someone who didn't know it had already been fettled looking at it and saying that a quick scrub and a lick of paint would spruce it up nicely.
It sounds like that Wilton must have had a fair bit of filler under the paint?
Get': It's a Scottish vice. Alexander Mathieson & Sons, Saracen Tool Works, Glasgow. They were a company renowned for woodworking equipment primarily.
