Ihateclevernames
So, with all of the other things that are going on around the property.........My shed is finally moved in place. I had to move it 150' through the woods using cut up poplar trees and a 12K lb winch.
Yeah, it was about as fun as it sounds.
Anywho.......now that it is in place and have the yard tools and chickens relocated, I need to get some power up there. I don't have the space to add another breaker on to the house panel, however I will once the new garage is completed.
So, I don't have many options as of right now with the exception of running extension cord across the yard to the shed and powering the shed through the use of a weatherproof inlet.
I only plan on running 2 lights and 2 outlets out there in the shed, it is really only important right now as I need to be able to keep the chickens warm during the cold months. I will have a ditch witch out here in a few weeks and can trench for the cable then, but in the meantime I would be able to get all of the boxes and NM ran inside the shed and chicken coop along with a few lights and power them all with the extension cord to the inlet.
Since the inlet will be in a box, it will make the changeover quick once I actually get it trenched properly.
So, with all that being said........running 12/2 UF to the shed on a 20A circuit eventually will be preferred, however I am not sure about the voltage drop to the shed. Once the building is complete, I will have a run of about 120' to the shed. I am sure that there will be some drop, however I will really only be running a few 60 watt bulbs and a few outlets that will power nothing more than a few small power tools from time to time and battery tenders.
Or will I need to use a 15A breaker?
Thanks guys
Thanks guys
