If its 100$ for them scoop it. Here they are 300 and sold fast, a new one is in the 500+ range now. The inverters are really revolutionary in some respect. They are the only stick machines that ever allowed real work from 120V. Mine cost 800$ but now the clones have really kicked in, the Everlast is dual V.
I am a career welder. Have about 10 machines. In todays world and with some perspective would do it all different today and abit of it is technology.
I will agree with the concept of the basic DC buzzer due to the fact its economical, works so super good at expert level and its reliable. Its still a standard and even though I have way more expensive machine its what I use for sticks in my shop.
However,,,,,,,,,,,,,,,, there are a lot of other factors in todays world to consider especially for the welderless.
I can do most work with 1/8 6011 and 3/32 7018, the good inverters are efficient and I havnt ran only couple 1/8 7018 from 20A ad if I turn it up to comfy will trip. It would probably do it for limited with a 30A breaker. I have only test ran it at 240 and it smokes them.
With 1/8 6011 and 3/32 lo hi it will smoke them from a 20A circuit, I tried a couple at 200 ft and it tripped the breaker at about 75 or 80A but at 100 ft or under not an issue, 90A or more not a problem. Worked right along never pay attn. to duty for fab work.
You can build with it and if you have 240 all the better if a guy was building a trailer or working on heavier farm equipment, had a real shop, this 1 machine would do the work. With the addition of a cheap genset you have a portable welder.
These are good for on the move. the cost is cheap but often no additional wire, cords or leads are needed and the whole unit is as big as a remote of yesteryear and cost only a fraction.
I have over the years ran my AC/DC at 115DC a whole handful of 1/8 lo hi as fast as you can way exceeding its duty, have ran a few buzzers like that in the day and never burn one up but a hobby guy isn't building a roofing bed in an afternoon either.
If a guy is equipped, has power etc, somewhere to keep it, a ****** is fine. Today I would reconsider it on cost alone, the inverter is so convenient on 120.
I repaired a forklift on a service call with one a while back. Didn't even take my service truck. Plugged in to the customers 120 and had about 15 minutes of weld. One section about 4 or 6 inches long needed bigger weld and I run 3 extra rods over it for a second pass.
I did use the Max on a building job and a thing I should have added right on was 25 ft of lead on the stinger. I like to hop and skip and you have to move the machine. For repairs its perfect with the unit close to hand, absolutely no excuse not to adjust it perfect. Super duper uber slick for process piping. Nuke work etc.
