New Compressor; What else do I need
Kilgore Trout
Northern Virginia
Hey everybody, recently ordered a new Makita MAC2400. It gets delivered this week.
First project will be doing a bunch of molding work (crown and baseboard). I already have a nail gun and ordered a a blubird 3/8 hose.
This is my first compressor (figured I would just go big and get one that I figured would be my needs for the next 10 years). What else should I order so that I am ready to go on day 1?
The near term projects I plan to work on are the trim work, building a fence, light impact work on the car (brakes), and of course inflating tires.
PaulyC
Quincy, MA
that compressor will likely have trouble running an impact. according to the spec sheet it only flows 4.8cfm at 90 psi. the average impact at load needs 15-20 cfm. but for around the house stuff running nail guns it will be fine.
dodge610
North Canton Ohio
You need one of these or one like that will run anything you throw at it.[emoji2]
Sent from my SAMSUNG-SGH-I547 using Tapatalk
theoldwizard1
SE MI
I don't care what anyone else says, buy a air tool "set" form HF. It includes 2 quick couplers some studs, blow gun, tire chuck and adapters to other "blow up" "things" !
It goes on sale all of the time for <$10. When it does go on sale, it is actually cheaper to buy this set than a coupler and some plugs !
inyoyote
I love my Mac 2400. Follow the break in procedure that is described in the manual. Also look at the plastic shroud near the air filter. I had to trim mine back a little bit to clear the air filter housing. I have run an impact with mine many times before I got a cordless. It will run it fine for removing lug nuts if you let it build up between nuts, which doesn't take very long. It won't run things like a die grinder or sander but I have used it for lots of lug nuts and other quick shot projects. For nail guns it the cats meow. It will keep up with a framing gun no problem. You could probably run a roofing gun if your a little patient. It will overheat if you don't give it a break every once in awhile. As long as you remember it's a small portable and not a big 2 stage, you will love it.
Warrenator
Newberg, OR
I would get some good couplers, the milton type v are very good and reasonable. Northern tool has a nice price and assortment. Tire inflator, blow gun to remove dust off things, and a moisture separator and pressure regulator. That blubird hose is nice. And I really like air powered DA sanders. They seem to work 10 times better than electric ones.
McLean
Seattle, WA
Agreed on the couplers. The Milton V type are nice, however, the M type would probably be sufficient for light duty tasks and are cheaper/easier to come by.
Also some nice hose will make your life easier. I like the Goodyear rubber type for straight and Plastair HoseKoil for coiled. But I'm sure there are plenty of other good options too.
