Easy outs and turbo sockets
2ndGearRubber
Pittsburgh
Turbo-socket, is the original maker of the product. You can buy them at their website.
Mayhew, SK, Matco, Blue-point, ALL rebrand the turbo-socket product. Likely more companies do as well.
Easy outs all ****. I have a variety of styles, they're all as aggravating as the last.
kwoswalt99
Detroit
I haven't had a lot of luck with easy outs either. I'm really good at breaking them. I've only used little ones though, so that could be why.
anndel
Hawaii, USA
I have the 25 pc set of Irwin Hex Head Multi-spline extractor set from Amazon.com for $50+change.
Mohawk Dave
SoCal
Now that I do the process correctly, I haven't had one break in a handfull of years...and I use them quite a bit on old machinery refurbs etc.
Left Hand Drill bits are numero Uno. Half the time they pull the ******* out.
Don't forget some heat, or ATF/Acetone mix. Or both and bring the marshmallows.
Also, there is Irwin China, and Irwin Hanson USA. (I think I saw Irwin Hanson China the other day as well, so now you gotta check all of them)
All my Hanson stuff is a little older, but all USA and same rebrand stuff as Snappy etc...
SuzukiGS750EZ
So what set or sets should I buy? I've needed both style, the drill a hole in the bolt and twist it out and the stripped nut/bolt head turbo socket. Also, left hand drill bit set? I don't know what common sizes for auto use, I just grab my grandfather's and use, but he has huge expensive sets.
SuzukiGS750EZ
That's what those are! I found a lone one sitting in the road and had no idea what it was
Finky198
North East
As said above It's more about the process than the actual tool. Steps like Heating, Cooling, penetrant, vibration, and proper tool use are all factors for being successful with any extractors.
zkling
Rounded or broken fastener removal is one place where the more tricks you have in the bag, the better off you are.
fatfillup
Finksburg, Md
Yes
And yes!!!
And experience is everything. And how do you get the experience???
By screwing up and learning what not to do:eyecrazy:
I am much better now then I used to be but still have lots of tricks to learn.
wafrederick
Holton,Mi
The spiral easy outs,they don't work most of the time.Expand on the broken off fastner too much after drilling it out.The flat square fluted ones work a whole lot better.Mig welder makes a great broken off fastner remover,weld a nut on it if there is anything sticking out.
MikeF2316
Thornhill, ON
I just had a spiral easy out work quickly with an absolute minimum of effort.
I broke the metal threaded end off my garage broom handle. But my largest Irwin spiral easy out had no problem with the broken piece! :lol::lol:
Mohawk Dave
SoCal
MikeF2316, extractors are awesome. But sounds like you need some larger ones for the future. lol
Here's a pic of a #12 I got.
Streetbu
Central NY
I just bought a set of Lisle extractor sockets. Just a socket set that fits the square on extractors and taps too. Already used one socket. Much better than trying to use a wrench or the little handle tool that comes with most tap and die sets.
