VW Brake caliper New sockets
rhandwor
Both Laser 6383 and HCB-A1629 sockets are a new ribe 9mm female 10 point socket.
They are apparently new.
If anyone needs one.
http://www.bay.com/ search item 321834753602
G_P
Central CT
Why do car companies do this? Is there a good reason to use an oddball fastener or is this just an attempt to force people to go to a VW dealership every time they need a brake job?
ChevyEFI
Phoenix, AZ
Probably like some instances of Torx, a manufacturer found a new and improved design they could show to be stronger than the previous design. Of course, since a regular hex bolt would have worked, it's a bunch of middle-engineering types having a bratwurst measuring contest at no tangible gain for the vehicle. But hey, at least someone has some improvement implementation fodder for their resumé!
Oh, and some people get wet when they can refer to the complexity of work they had their dealership accomplish on their car, so there's some level of marketing to it.
blazinPond
Central MN
Thanks for the heads up.
I plan to DIY when my brakes are due and this appears to be necessary.
I'm still curious if this is needed just for a pad change though.
abvw
Toronto, Canada
No, I have never had to remove those pad anchors on Brembos. Outside of the factory the only people who might need this is brake caliper rebuilders.
Sent from my Q10 using Tapatalk
