Belt Sander/Grinder Build
proorange
Priceville, Alabama
After looking around for a nice belt sander I realized one thing, they are expensive. What I was looking for was going to run me $1500 to $2200 and I just couldn't justify that.
I got to looking around on various fab sites and had seen where people were building there own and decided that was the route for me. After about 2 weeks of gathering info on material and parts I went after it. It took about 2 weeks working on it when I could but I am so very happy with it. It's powerful and will flat get the job done.
It's a 2hp motor with variable speed pulleys(1200, 2600 and 5250 FPM) and holds a 2x72" belt. I added a flat platen attachment, slack belt attachment for deburring and 10" wheel for a bit more precise edge grinding. I made two work rest, a 4x6" and a 4x15".
It's been challenging yet rewarding building this grinder, although it's not finished yet I'm sure pleased with the outcome so far, I've even had a couple of friends ask me to build them one.
Here's a few pictures of the beast;)
jam022316
Indiana
Congrats on a great build!! That thing kicks ***!! How much would you say you have in it and where did you get the plans?
pipehack
chicago
that's awesome!!!! Was there a particular site for plans???? If so can you direct me to where they came from... Or at least what fab sites. Thanx ... Pipehack.
P
proorange
Priceville, Alabama
The cost I haven't figured yet, maybe I don't want too:shocking:
I looked at the KMG, Bader, the No Weld and a few other homebuilt setups and went from there.
P
proorange
Priceville, Alabama
Here's a few sites for reference. The wheels from Beaumont are pricey, excellent quality but it eats up a chunk of change.
http://www.beaumontmetalworks.com/
http://www.cnccookbook.com/CCDiscSander.htm
http://www.mickleyknives.com/html/no_weld_grinder.html
As for the 10" contact wheel, I got that from Grizzly then bought some bearings and machined the wheel for bearing fit. The wheel, bearings and shipping I only have $100.00 in them compared to $308.00 for the KMG. Although the wheel is nice for the KMG and is a billet piece compared to cast for the Grizzly, I found something else to buy with the extra $208.00;)
The part number for the Grizzly 10" wheel is G9242.
P
proorange
Priceville, Alabama
What keeps the belt from walking off the rollers?
The tensioner and drive wheels are crowned. I can run the belt a 1/2"(probably more) off the rollers and will will still run true. It's amazing how well the tensioner/tracking system works on these types of grinders.
Jim Stabe
San Diego, Ca
Nice work! It's very coincidental because I am just completing a very similar machine using similar components also on a beer budjet (I only had to buy $120 of stuff over what I had laying around the garage). I have one of the Grizzly 10" wheels as the drive wheel and two 4" rubber wheels from a company called Sun Ray. I built tracking adjusters into the small wheel mounts thinking I could get the belt to track without crowning the wheels and in fact I can get it to track very well. The problem is that it is easy to push the belt off center with a little angular pressure on the belt. I need to crown at least one of the smaller wheels, possibly both. How much crown did you put into your wheels and how did you do it? I have pulleys that run the machine at just over 6,000 SFPM for using 2 x 72 ceramic abrasive belts.
Again - nice work
Jim
P
proorange
Priceville, Alabama
Again - nice work
Jim
Thanks Jim. I bought the wheels from Beaumont and the best I can tell using my Smart Tool is it's around 3-4 degrees.
Are the Sun Ray wheels polyurethane?
Jim Stabe
San Diego, Ca
These are the wheels I got in a 70 durometer hardness. http://www.sunray-inc.com/detailwheels.aspx?ID=112
I found out today that they would have crowned them for me when they made them if I had just asked - who knew? Now I have to do it myself. I do have a lathe so it shouldn't be that much of a problem as long as I know what it is supposed to look like. Here is what I came up with, I still have to wire it, make the workrest and a platten to go under the long portion of the belt.
P
proorange
Priceville, Alabama
Had a few PM's asking if I'd be interested in furnishing all the parts ready for assembly/welding so I'm working up a price for doing this so if your interested just PM me and I will let you know what the cost will be....as soon as I get it figured:lol_hitti
-B-
Northshore of Boston
Nice work i have wanted one for these for a few years now they make mitering tubing so much easier and fledgling knife making too.
hombre
yah this is a real usesful post. i mean all the deleted pictures really help the rest to us great work. ma figueroa
healing
Here's a link to the one I made. Had a motor sitting around and some scrap steel. The contact wheel was a little pricey $100-$150 if I remember right. Hard to believe its had 26000+ views on youtube
P
proorange
Priceville, Alabama
Sorry hombre, changed servers and forgot about these. You sit tight while I go and get them loaded up. If you have any questions just press 1 for English....saavy
LoneGunman
The Gunshine state
Damn NICE work Jeff. Are the smaller wheels steel or aluminum? I think I have enough aluminum to make them on my lathe, not sure how they'd hold up though, I'd imagine it would be fine.
Jim Stabe
San Diego, Ca
The wheels on this machine were made in a high school metal shop project in 1960 and have been in fairly constant use ever since. Cast aluminum with bronze bushings running on a 1/2" mild steel shaft. I just made this machine a few months ago when the frame on the old machine broke and all I did was clean the 50 years of dirt off the wheels, there was absolutely no wear in the bushings or crowned faces.
P
proorange
Priceville, Alabama
Thank You!! They are aluminum Gunman. I believe they are a 1.5" and have a slight crown built in to help in the tracking of the belt.
LoneGunman
The Gunshine state
Can you post a few pics of your knives? I just like seeing knives made by beginners, I have a few from a friend of mine, best knives I have. Sorry for getting off track OP.
Neal
Very nice build.Sorry this post is almost a year late..lol..I am building one of these but I had a question about the wheels.Is it ok to use all wheels with rubber or urethane or does all except the contact wheel need to be bare alluminum.Thanks for the help
Neal
P
proorange
Priceville, Alabama
Neal
Thank You:)
I'm not sure but I have seen it done with urethane wheels.. I really don't see why it wouldn't work though. Good Luck with your build and if you have any questions feel free to ask, I'll try my best to help.
