Recommended Tap and Die Sets?
danwolfgang
CT
Any recommendations for a tap and die set? The first thing I did was try searching here, but "tap and die" doesn't find any results -- I'm guessing the three-letter words are to short to search with? Anyway, recommendations? I need something general purpose -- homeowner and light automotive tasks, metric and SAE. What would you recommend, and why?
Ponchoguy
I have a USA made Craftsman set. They are made by Vermont American. Reasonably priced and get the job done.
D
danwolfgang
CT
Some reading leads me to believe I want a thread restorer kit instead. Hmm...
zakmartin
Seattle, WA
I have a complete Greenfield set that I bought at a Coast Guard surplus auction back in the early-1990s. It's well over 100 pieces in metric and standard. It came with the foam insert but was missing the metal case. The whole thing set me back less than $20. They're still in basically mint condition. Every time I think about putting them up for sale, I think about how much they'd cost to re-purchase if I ever decided to start a manufacturing business.
PSD_Ryan
When i was working in the oilfield, I bought the big NAPA set. It served me pretty well. I always fill the grooves of my taps with grease before using them.
CJM8515
Laugh if you want, but the 40pc harbor freight sets have worked fine for me. The handle sucked so I bought a new one, but other than that Im happy. But I dont use them to work on anything more than hobbyist stuff. Cut some threads on bolts, tap some minor holes, that sorta thing.
Cato
Alhambra, California
Do you really need a whole set?
I get by fine with a small DeWalt set I got.
I regret not just buying the dies and taps I need one at a time instead of having one's I'll probably never use.
pauls_workshop
Indiana, USA - Underappreciated Place to Live!
I've had the plain jane HF set for awhile and can only complain a little. Now, not the cheapest, but the middle priced set. The die holder tool is terrible, but the taps/dies are OK if you know how to use them (cutting fluid, 1/4 turn, back out, repeat). Yes I know a good US made set is much better. But if you only use them once a month, the HF middle set isn't terrible. Pros need much better. - Paul
WhiskeyRanger
I like having whole sets at home. At work, I just have A small Bosch set (1/4-20 through 6-32) that has just the taps and tap drills in a case.
Having sets has two benefits, everything stays organized, and you (should ) have the right tool before you need it. Very rarely do I start a project knowing ahead of time I'm going to need to tap something (except at work obviously) and its usually after the store is closed.
Of course, you could always compromise and buy a cheap HF set and replace the commonly used ones with better quality items as needed.
RickP
Annapolis, MD
Before you decide, you should really try out the Gearwrench ratcheting handles, which work with both taps and dies. I picked up the larger model to work with large diameter hex dies (1/2" pipe thread), but now I wish I'd gotten the entire Gearwrench tap & die set.
The quality of the Gearwrench handle is just ridiculously good, and the heft of it is amazing compared to using the cheap HF stuff. And the handles also work with pass-thru sockets, if you ever want to try those. The Gearwrench set isn't cheap compared to HF, but I think it compares pretty well to the other quality brands - $140 for a 75 piece metric/SAE set.
LumpyMusic
Phoenix Arizona USA
^^^ This.
I use about four sizes of fasteners in my shop. Any time I add a new size I buy a set of Irwin or better PTB taps and two dies. That costs me maybe 20-30 dollars. To buy a "set" of the same for every size #6 through whatever, would cost hundreds of dollars. And I'd have dozens of sizes I don't or won't ever need.
Put another way, for roughly 100 bucks, I've got taps and dies, good quality, for all the sizes of fasteners I use, for any flavor of tapping (Plug, Taper, Bottom). Much better quality and longer lasting tools than if I were to spend that same 100 bucks on a set of every size in the world.
Sgt Lumpy
oldtools
For home use, Irwin, Hanson, and Vermont America. For industrial use, Morse, Greenfield, OSG, and Cleveland.
CobraRed
Handle is great, taps are carbon steel which on a 3-4 level scale of choices is at the bottom.
RickP
Annapolis, MD
Gotcha -- thanks for the info. :thumbup:
I didn't know anything about the GearWrench taps, so I'll steer clear of them. I agree that the handle is great, and I've used it for taps, dies, and sockets.
RickP
Annapolis, MD
The older Craftsman set (>25yo) are really pretty good ! Mine came in a big blue molded case.
I have one of the really old sets (>65yo) and they are great quality -- very heavy duty with fully adjustable dies threads. The only problem is finding parts for them.
This is my set, complete with the original wooden box from 1948:
View media item 55430
You can still find them on fleabay every now and then.
zeke67
Houston
I have stuff from Irwin, Hanson and Vermont American. Mostly the first two. Also some Kastar stuff which is good.
TNToy
West Tennessee
This. I have the large Irwin set at home. It's good enough there.
When I break something off flush in a cylinder head in a dozer at work, the machine shop crew shows up with something out of the latter category (usually Greenfield or Cleveland) and does the job.
Tiny Jackson
Schiller Park, IL
Exsctly. Just one single greenfield hss tap 1/4 or above is above 20 bucks if you bouggt it new. I have an assortment 9f greenfield, osg etc. That were all aquired in singles whether new or used.
Amish
Iowa
I have snapon tap sets. When I break one I just give it to my SnapOn guy and he hands me a brand new one. I picked up my sets on eBay and got great deals on them. I didn't pay anything what they ask for a new set.
